PM's Private Messages
Iniciado por Martin555
7 replies 6 me gustas Última actividad: hace 6 años
Thanks Martin 🙄
I have just finished deleting all the PMs I have ever sent. 😭
Graham93
Le gusta a Martin555
Sorry Guys I have led you all up the garden path.
I wrongly thought removing Privet messages would save a lot of server space.
Makes sense, there's only one record for a private message. Deleting it would delete it for both the sender and receiver. So only the function to delete your own PM's is available.
Space wise - PM's are not really using much space or causing issues.
I'm working on the emails (still). I can assure removing PM's won't help on that front 😊
Stephen
Vice Admiral Colin.
Why are you unable to delete the received messages ?
Good idea Martin, I'll have a look at mine while I'm waiting for the notification emails to come back.
I can only delete the messages that I have sent, not the recieved
Hi Graham,
The right hand side of the message there should be a tab that says 'Edit" click on that.
When it opens there is a black strip at the top, and on the left of it is a little bin icon click on that and it will go.
As far as i know unfortunately you will have to delete each text box individually.
Hi Martin,
How do we delete them? The only options I can see for a message is to ‘reply’ or to ‘flag’. Can’t find ‘delete’. Perhaps it’s so obvious I’m missing it 🤔
Graham93
Hi Guys,
I spent a lot of time today going through my Private message's and deleting lots of them.
And i still have a lot to go through.
I suppose it is my fault for letting them build up.
It would be a good idea if we all went through them and deleted the ones we on longer need.
We could save quite a bit of valuable site server space.
Le gusta a Seanympth and Colin H
