Glue option query
Iniciado por Allan
9 replies 13 me gustas Última actividad: hace 6 años
Glue option query
Hi Ian
Yes, that seems to be what I am picking up in regards to slow setting epoxies, thanks for that. I'm got mine ordered :-)
Thanks
Allan
Glue option query
Hi Allan
I always find slow setting epoxies also produce a much stronger bond😊😊
Le gusta a Fred
Glue option query
Hi Ian
Many thanks for your reply, thats very helpful.
Much appreciated
Allan
Le gusta a Fred and Ianh
Glue option query
Many thanks Fred, it sounds the slow setting types are more appropriate for my needs, thanks for your reply, much appreciated.
Allan
Le gusta a Fred
Glue option query
Many thanks Colin, thanks for sharing your thought on this. Much appreciated.
Allan
Le gusta a Fred
Glue option query
Can't beat genuine Araldite 24 Hour
Ian
Le gusta a Allan
Glue option query
Hi Allan (Blacknbluedog)
Now this is a can of worms, in the past I have used
"Stixall" Adhesive & Sealant Clear - "Gorilla Glue" clear - Evo-Stick "The Dogs Bllcks" clear and 2 part epoxy, all slow setting times.
Evo-Stick "Sticks like sh*t" clear is a grab adhesives short setting time.
In the end for fixing the deck beams I all ways go for one of the new Hybrid adhesives with a slow setting time and most are waterproof.
Fred
Le gusta a Allan and Ianh
Glue option query
Good question Alan, my preference is a 2 part epoxy. And the longer the setting time the better the bond, as it is usually flexible enough to allow for minor movements without breaking.
If you can be sure of no movement then a fast set such as is available from poundland.
Le gusta a Allan and mistyoptic and
Glue option query
Being a newbie to the hobby of boat building, can i ask advice on the best glue type to use to attach wood fittings to a (kit) fiberglass hull please?
Many thanks
Allan
Le gusta a Colin H
