Props
Cheers fella
Props
I have severe arthritis myself which controls the pace of my builds.
But the feeling of fulfilment at seeing the finished model is what keeps me going.
We all try to help each other, don't think as a newby on here you can't offer suggestions.
With your mobility problems you could find easier ways to do things that we don't know about. YET.
As for your plastic prop if it's the correct size and pitch it will be fine, props can be changed so easily its often best to wait and see how it performs before going to unnecessary expense.
Props
Do not worry about how long it takes to build your boat.
As long as you enjoy the hobby time will have no meaning.
If and when you have any questions just ask away as i am sure the members here will help you.
Props
Props
Although Martin is correct in his wise answer to your question, some manufacturers label their products the other way.
So as Martin said if you're using a single prop it doesn't matter.
The main points to keep in mind are the size and type of model the speed of the motor in relation to the prop as some props may look good but won't drive the boat efficiently.
Hope that this hasn't confused you, post more details with pictures if possible and one of us members will definitely be able to help you.
Props
Firstly i would like to welcome you to this fantastic site.
Reference prop rotation.
Assuming you are looking at the prop from the aft of the boat.
I think it is a left hand prop.
Although it dose not matter with a single prop as you can always reverse the motor rotation by reversing the motor wires.
Will you be doing a build log of your Slec RAF rescue launch
Props
Le gusta a
Cargando…
