Airbrushes
Iniciado por Seawolf
21 replies 40 me gustas Última actividad: hace 6 años
Airbrushes
"they are too busy making chop suey"
Nope. I doubt that Rick.
Chop-suey is a creation of our American brothers.
A sort of mishmash of Chinese dishes / ingredients adapted to American fast food preferences - 'All In' 🤔.
I don't think that a Chinese chef worth his Sichuan pepper would dream of making Chop-suey😠
I just know that I never ever saw anything remotely like that on a menu during my visits to China.
In some 'établissements' in Beijing I'd probably have been thrown out if I'd even asked for it!🤕
But; whatever tickles your palette😉
Bon appétit, enjoy your meal (邦阿切特, 請享用😋)
Le gusta a Ianh and Martin555
Airbrushes
Brian,
My better half replaced my old 'cheapy' with a set from Amazon and these are the current prices -
GANZTON Airbrush Set Double Action Trigger Paint Spray Gun Kit Professional Sprayer Air Paint Control Gun with 0.2mm/0.3mm/0.5mm 9cc CUP for Makeup,Tattoos,Cake Decorating,Crafts @£29.99 +
ABEST High Quality Dual Action Airbrush Compressor Complete kit Paint Tool for Art-and-Craft Projects Tattoo Hobby Model Craft Spraying AC06K30W @ £34.99
The second airbrush is crud - BUT, the compressor is good enough for anything from very fine lines at low pressure to whole hulls - it's worth binning the cheap ABEST airbrush to get that alone, or just use it for general priming coats.
The Ganzton airbrush is amazing for the price.
I did polish the needle first, but it's as good as a 'posh' one a mate lent me to try out. Not the cheapest way of doing it, but after a year and a half, it's still going great guns and I ain't changing it for the foreseeable future.
By the way I'm no Amazon fan, but wifey likes 'em so for once they did a good job.
Cheers Andy
Airbrushes
Do you know where She buys them Rick?
Her super-fine detail work is superb😉
Le gusta a Ianh and Newby7
Airbrushes
Don't see many Chinese panel beaters around these days do you!😁
BTW I've heard that the best panel beaters come from the Caribbean😁
Happy bashing and spraying folks👍
Airbrushes
Hi Martin, will do that not used enamel paint for years a big learning curve again. Thanks for info......
David
Airbrushes
Hi Martin,
They all work well with the correct cleaning and maintenance. Considering you buy half a dozen cheap ones for the price a basic Badger. Just use some old fashioned pipe cleaners!
I use a Chinese Panel beaters touch up gun that holds about 200ml on a 45 PSI line for major painting.😊😊
Le gusta a Martin555
Airbrushes
Ian,
The other good thing is if a cheap airbrush stops performing as it should then you just strip it down and keep the useful bits such as the 'O' rings.
Le gusta a Ianh
Airbrushes
Most of them work well with a bit of tuning and maybe a replacement O ring!
Airbrushes
Same here Martin👍
Can get a litre can of WS for similar price of a titchy bottle of Humbrol or Revell thinners.
Dilute to the consistency of milk (NO cream😉) and Bob's yer uncle and what's 'er name's yer aunt😁
Le gusta a Rookysailor and Ianh and
Airbrushes
That is what i do Ian.
And they work really good for me.
Le gusta a Ianh
Airbrushes
Hi All
You can get the Far East Airbrushes to work better by polishing the needles.
Look on You Tube Plenty info on turning a nasty one into something that works
Le gusta a MouldBuilder and RNinMunich and
Airbrushes
Hi David,
Not long to wait now LOL!!
One little tip if you are planning in spraying Enamel Paint.
I use Humbrol Enamel paint and instead of paying out for the fancy Enamel Thinners i use good old fashioned 'White Spirit" to thin the paint.
Have been doing this for years and not a single problem and it is a lot cheaper too.
Le gusta a Ianh and MouldBuilder and
Airbrushes
Good morning Martin, I have a cheap and nasty one horrible made, wife won't let me use the compressor till Christmas as it's a present. Have not done anything yet with Tina as having a loft Conversion work has only restarted today. So that will be my build room
David 👍
Airbrushes
Hi David,
Try a cheap airbrush from ebay then if it don't go according to plan you have not wasted to much money.
Le gusta a Ianh
Airbrushes
Hi Pete, thanks for the information and will look at the Badger airbrushes just space is restricted so thought I would try the cordless compressor.
David👍
Le gusta a Rookysailor and Martin555
Airbrushes
From what I can remember most airbrushes run at 12-15 PSI for general use provided hat the paint being used is thinned correctly ( Suggest you google for the paint being used) I use Tamiya. Good makes are Badger and IWATA
Le gusta a MouldBuilder and Martin555
Airbrushes
I also have an Iwata compressor Davis, but the larger one, at the pressure you are talking about, I would use either a Badger 200EX or a Badger 150IL, I have both, and they work great on low pressures.👍
Cheers, Pete
Airbrushes
Hi Rick, thanks for the information, I have had Badger airbrushes in the past but many years ago as just returning to the hobby after a long break. What I have considered is the Iwata Neo gravity fed as the compressor is only low power output.
David
Airbrushes
Brian I have Badger air brushes.Single action and duel action that I find work well for me.A friend uses Iwata brush and like his.
Not sure you can go wrong with a good air brush.
Rick
Airbrushes
Hi everyone, I have a Iwata battery air compressor output is 10psi_20psi what I am looking for is a suitable airbrush compatible with this unit. Any help would be appreciated.
Thanks
David
Le gusta a Martin555 and Ianh
