motor
Iniciado por brianupyonder
3 replies 4 me gustas 0 seguidores Última actividad: hace 6 años
motor
Hi Brian, A lot depends on what performance you are looking for and what water you will be sailing on. If you are looking for a reasonable performance with a low cost try the MFA 385, a well made motor which can be fixed using the supplied mounting plate or, without the plate, fixed by the two normal mounting holes. Higher performance using a brushless motor can be achieved but what good if you are using a small pond. On a larger pond then the greater power and speed can be more easily observed and appreciated. Geoff L.
Geoff L.
Le gusta a jacko
motor
hi everyone
im after advice again,what size electric motor would you fit in a patrol boat 20 inch length
6 inch beam
all help appreciated
cheers brian
brian
