HMS HOOD Keel
Iniciado por Alan
10 replies 11 me gustas Última actividad: hace 6 años
HMS HOOD Keel
Interesting to see a model of something like HMS Hood being built in the bread and butter method. I thought it was only used in smallish yachts. I remember making one when I was about twelve. My grandfather cut out the various layers for me and I smoothed off the outside and fixed the deck. I wonder what happened to that model?
Cheers, Nerys
HMS HOOD Keel
The good part is you can take your time and study the build until you feel comfortable to start.
Rick
Le gusta a Martin555
HMS HOOD Keel
Hi Alan,
If the plans for this model are drawn for bread and butter construction there will not be any position marked for individual vertical bulkheads.
Also there will not be much in the way of instructions.
Have you made a model boat hull using the bread and butter construction technique before ?
There are some good videos on utube that will show the bread and butter technique.
Le gusta a Nerys
HMS HOOD Keel
Building from plans can be very demanding but also gratifying. I would suggest go on line and search for build logs of the Hood and keep reading the plans until you get a better idea were to start.The best I can say is to cut out all the frames and mount them on a building board that will give you a start.Good luck.
Rick
Le gusta a RNinMunich and Martin555
HMS HOOD Keel
That is the plans but there is no instructions and the printing is a bit hit and miss
HMS HOOD Keel
The plans are from sarik hobbies there is no scale on the plans but the finished model is 54 inches and the diagram for ribs has no cut out for the keel and the plans tell me to use 1/4 marine on the bottom if I do that the ribs will sit on top and when I plank up I will a lot of filling or sanding to do I have tried to get another plan from America as it shows the ribs cut out for the keel and you get instructions that tell you how to the ones I have got from sarik hobbies you get no instructions and for £16 you would at least get some can you help
Kind regards Alan
HMS HOOD Keel
Hi Alan.
What plans do you have.
Are you scratch building or do you have a set of parts.
If you can post some pictures of what you have that would help .
I have built Hood in 1/128 scale and if you look at my latest blog I am undergoing a major refit on HMS Repulse at this time.
Happy to help if you can supply more info.
Regards Bill.
HMS HOOD Keel
I have just bought the plans for HMS HOOD can anyone explain how the ribs are laid down as there is no instructions if they are put on to a centre spare
Kind regards to you all Alan Bell
Le gusta a Martin555 and Scratchbuilder
