Electric
Iniciado por Dean007
1 reply 3 me gustas Última actividad: hace 6 años
Electric
Hi Dean,
Can you post some photos of the equipment that you are using and how you have wired it all up.
Also if you could explain exactly what you do and what happens.
The more information you are able to give us the better it is to try and sort out what can be done to solve the problem.
Le gusta a marky and Colin H
Electric
Hi can anyone help I'm building a drumbeat of deven I have set up all the electrics but the motors only run for 10 seconds then stop I'm using a hobywing quicrun 880 duel brushed speed controller and mag comp drills torpedo 500 motors any ideal
Le gusta a Martin555
