34” Fairy Huntsman
Iniciado por Boat660
1 reply 1 me gusta Última actividad: hace 6 años
34” Fairy Huntsman
Hi, There the motor is most likely a bit too powerful but could be fun!
you have plenty of toque (410KV)
Start on 3S then 4S then 5S
Same with props start small 30mm then work up
I have a set of props of various diameter and pitch to chop and change.
This way you will be able to control the boat, and your preferred runtime, 5mins or 25mins, torque steer, trim tabs, trial and error is often the way to go.
If you start on 5S with a 55mm high pitch prop, You could have the first Flying Huntsman or a Smoking Motor or a wrecked boat.
I had/have a 34'' Huntsman that had twin screws (2x 2860 on 3S) and twin rudders as per the original boat but its performance was a bit disappointing, compared to a racing hull.
The real boat originally was used for off shore racing so designed for the rough water of the open sea.
I would suggest a water cooled motor mount for an out-runner motor
Even better find someone who has used the motor in a boat will give you a starting point.
Specs.
Turns: 12T
Voltage: 4~5S Lipoly
RPM/V: 410KV
Internal resistance: 0.026 Ohm
Max Loading: 55A
Max Power: 1310W
Shaft Dia: 5.0mm
Bolt holes: 25mm
Bolt thread: M3
Weight: 260g
Motor Plug: 3.5mm
Go for it!
Regards Roy
34” Fairy Huntsman
Hi All
Started to build the huntsman 34”, setup will be brushless. I have sitting in the workshop a Turnigy aerodrive 4250 (410), can anyone with brushless knowledge advise me if this would be ok.
I would “assume” that it would be, but possibly too powerful 💥, if this is the case I could always change the throttle curve?
Any advise would be appreciated.
Thanks Russell
Le gusta a Martin555
