Missing plans and construction booklet
Iniciado por stevecw
11 replies 7 me gustas Última actividad: hace 7 años
#12 1
Thanks everyone for the help in getting hold of these documents. Thanks to a member I am now sorted and hope to building again soon.
Le gusta a Martin555
#11 1
Hi Steve That’s fine just let me know if you need them.
Ian
#10 1
Good news Steve👍
Don't forget the build blog an' pics please 😊
#9 1
Thanks for replying. I now have several lines of enquiry so hopefully building will recommence very soon.
Steve
Le gusta a RNinMunich
#8 1
Hi, a fellow member may be making PDF documents available to me but if that doesn't work out I will pursue your offer with you. If that's ok? Many thanks for replying.
Steve👍
#7 1
I have plan and booklet for Presedent KD Perkasa if any help
Hi Steve,
RHBaker here on the site has built a superb version of the Perkasa type HMS Brave Borderer, maybe he can help you out?
Check out his Build Blog here-
https://model-boats.com/blogs/40884
Happy hunting, and happier building and sailing!
Ok thanks for the suggestion and I will bookmark for the future.
Battlecrafts supply lots of bits for the KD perkasa they may be able to point you in the right direction for plans etc
Thanks for the suggestion but yes tried that but no longer in business.
Have you tried contacting the makers of the model kit to see if they could supply you with a set of drawings and instructions ?
Assuming that they are still in business.
Nearly 25 years ago I was bought the kit for the KD Perkasa MTB and the plans for the Vosper Fire Tender (34" version). Having a young family at the time construction didn't very far until now. Having more time on my hands I am returning to where I left off but have found both sets of plans are missing and the construction booklet for the Perkasa. Can anyone help advise where I might get the missing items? In anticipation...
