34" fireboat fittings.
Iniciado por Colin H
1 reply 0 me gustas 0 seguidores Última actividad: hace 15 años
HI Colin,
The only fittings I have found so far for the 1/16 Fireboat are from Model Slipway, the monitors are non working, but you could try and fit some brass tubing or if not take the easy away and buy some from Graupner or Robbe. The fittings are whitemetal and are very good, does not really affect the upper weight that much.
HI fellow boaters,
I'm In the process of a full refurb on my aerokits 34" fireboat and have not been able to locate some fittings.
Can anyone point me In the right direction as to 1/16th scale parts, I require the following parts:-
Rescue Davit with deck fittings.
Mushroom vents.
Danforth Anchor.
Fire Monitors. (WORKING)
Fairleads.
Breeches connection system.
Forward Mast Crutch with fitted Light.
Port and Starboard Working navigation lights.
Suction pipes for water.
Help In locating any of the above would be appreciated, I am located In west midlands
close to welsh border.
Will be updating photos very soon.
Thanks Colin.
