Noodle Jet Boat
Iniciado por Shopper
6 replies 7 me gustas Última actividad: hace 8 años
Noodle Jet Boat
"........there isn’t a huge amount of swivel on the buckets, was thinking of putting a mixer in rather than a rudder?, I suppose it’s just trial and error.... ...."
If you put a small 'dagger plate' on the keel, like the power racers do, that will improve the turning no end....
Le gusta a redpmg
Noodle Jet Boat
"....There were plans for a noodle boat in a fairly recent model boats mag..."
Several years ago I drafted up an EeZeBilt RIB. This used foam pipe insulation (ready-split!) for the inflatable section, had a standard brushless prop and used a servo hidden in a dummy outboard to swing the outboard for use as a rudder.
I never completed the boat, and did not publish the plans, but if there is some interest I will look at revisiting the idea. Here are a few pics of what the boat was to look like:
Le gusta a redpmg
Noodle Jet Boat
Hi John, yes, there isn’t a huge amount of swivel on the buckets, was thinking of putting a mixer in rather than a rudder?, I suppose it’s just trial and error....
Noodle Jet Boat
Looks good, you may need a rudder if you have problems turning! I had a similar boat which was fine in straight lines 😁
Happy sailing.
John.
Noodle Jet Boat
There were plans for a noodle boat in a fairly recent model boats mag ,though not jet propelled,can't find the issue as the wife has "cleaned up my corner"👍it's here somewhere.
Le gusta a RNinMunich and terry290654
Noodle Jet Boat
Looks good so far!
Let see where you end up at!
Cheers, Ed
"Fair winds calm Seas"
73
Noodle Jet Boat
I’ve decided to realise a plan I have in my head, I’ve seen a craze for building ‘Noodle Tugs’ based on the swimming aids you find at the pool, and want to see if I can incorporate jet drives :-)
As with most projects start with a sheet of ply and see where it takes you, so I fitted the Noodle, shaped the transom and fitted a couple of jet drives, still lots of detail yet to be thought through but it will either work or it won’t!
Le gusta a RNinMunich and retirement-hobby and
