Thames Barge Plan Kitty
Seguidores (4)
the Kitty plan...I did try to search it in vain too,but try to look e.g. here > https://www.modelboatmayhem.co.uk/forum/index.php?topic=5056.0
It´s hard to say , but the only thing I can advise you now, try to enlarge the picture of Kitty under sails (you will find it on the net), then find a sailplan of some barge that has similar rigging there, and
compare the sailplan for your model.
When I built my models, I did the same. As I looked at sb Kitty model photos, I think the orginal plan is probably very simplified. Then, as far as the details are concerned, it is good to do them also by photos, or use parts from Mastman.
Maybe you can find more ...
Tom
some months ago I put here list of tsb plans..maybe you would choose other plans as well.....
Known Scale Plans for building:
WILL EVERARD MAP Plan – believed not to be a true scale plan!
LADY DAPHNE Underhill Plan
Models by Design GRP Hull
CAMBRIA L E Zouch detailed plan
SIRDAR Richard Chesney Plan from MAP 1962 drawings
JAMES PIPER Richard Chesney Plan redrawn to 1/24th Scale from
MBO Survey 1958 / Weddell Plan
VERONICA Richard Chesney Plan from MAP 1962 drawings and
J M Russell 1962 MBO survey
WESTMORELAND TSBT small scale Plan
PORTLIGHT MBO Survey 1963
and sister vessels XYLONITE and REMINDER Mastman GRP Hull
VENTA David Macgregor Plan
Kingston Mouldings Hull (Close to scale)
KATHLEEN E J March / MAP / Remploy Plan
GIRALDA E J March / MAP / Uffa Fox Plan
1896 Champion Barge Small scale E J March Plan
KITTY MBO survey 1963 - Hull and Sections only
VERONA Hull and Sections only
MAY Outline Hull and Sections only
WOLSEY Hull and Sections only but from detailed L E
Zouch 1962 survey
REDOUBTABLE Hull and Sections only
NORTHDOWN Hull and Sections only
Some of the above are outline or limited detail hull drawings and sections only. The scales are variable but can be printed to 1/24th if required
It may help too, I think
for more infos about model barges I can recommend Ivor Bittle pages => https://www.ivorbittle.com/
Tom
https://www.modelboats.co.uk/forums/postings.asp?th=131302&p=13
https://www.facebook.com/groups/1036890286476399/members/
New site doesn't seem to to too happy with web links ☹️
Let's try this one
https://www.google.com/search?q=Sailing+barge+Kitty&tbm=isch&source=iu&ictx=1&fir=x_zIX2B26JmGTM%253A%252CavcAy0DhOJsTRM%252C_&vet=1&usg=AI4_-kQqtLg-A1yUtGqiWU3Pt6tuYLhNOg&sa=X&ved=2ahUKEwjG75j2oJnhAhWsMewKHZ0eAcUQ9QEwAHoECAYQBA#imgrc=_&vet=1
At least here there are lots of photos showing the rigging Nerys.
Doug 😎
Or
https://www.ebay.co.uk/itm/Model-Boats-Magazine-years-1999-all-months-fantastic-condition/113691043248?hash=item1a7883a5b0:m:mIG_RQZ3iebZnrdal68hhGQ&var=413816087910
Try again
http://magazineexchange.co.uk/cw/model-boats-magazine-april-1999-issue.html
http://magazineexchange.co.uk/cw/Model-Boats-1999
Doug😎
You can find the mag tomarack mentions here
Have fun, don't forget to post the Build Blog 😉
Cheers Doug 😎
I found this> Barge Kitty model
Issue 581 of Model Boats was April 1999. The mag is marked Vo149 No 581 2 APR-29 APR 1999.
There's a 9 page article with a multitude of pics to help anyone building this model .
Sorely I have not this issue -maybe somebody can help.
Tom
Kitty was a plan by Richard Webb, he had a web site www.scalemodelboatyard.co.uk , sorely very long time not availlable.
There exists more tsb plans , put > thames sailing barge model plans < into Google.
I think you could choose something ..if you are thinking about RC model ... I would recommend some finished hull. There are also a number of other barge plans, such as Lady Daphne or Veronica. Model Veronica goes to buy as a kit from Traplet -
https://www.sarikhobbies.com/product/thames-barge-veronica/.
On the Internet are also reduced plans of other barges, but these must be adjusted for the construction of the model.
Tom
Le gusta a
Cargando…
