Help identifying
Iniciado por juskiddin
8 replies 16 me gustas Última actividad: hace 7 años
Help identifying
Finally got the boat going and learnt a big lesson. I was using a prop shaft the telescopes and it did. With the motor running hard I think I hit some weed which caused the prop to have extra pressure on it. The shaft then collapsed in from the added pressure and I lost all propeller thrust. Could hear the motor revving and no motion. Had to be rescued by a model sailing boat!
Le gusta a BOATSHED
Help identifying
Purchased in Ross when on holidays last week but live in Sydney! So a bit far to come. Like the look of your boats.
Le gusta a BOATSHED
Help identifying
Hi justkiddin
I live in Hobart, so not to far away from you mate.
My mate and I both have Sea Hornets, his has a funny cabin on it also.
Mine is build by the original plans.
Brushless 28mm 1900kv, 45Amp ESC on 3S with a 32mm prop.
Was GPS at Lauderdale canal at 45KPH.
WE sail on a Saturday morning from 9 to 12, so if you are down this way call in.
Canabus
Le gusta a petercbrown and Donnieboy and
Help identifying
Thankyou all so much. Yes a sea hornet with a funny cabin.
Wonder how it ended up with this cabin?
Wonder how it ended up in a little country town called Ross in Tasmania Australia?
I'm sure i'll have some questions in the future re motor and batteries.
Le gusta a BOATSHED
Help identifying
Boaty I agree with Canabus. The shape of the hull does appear to be from the Sea Hornet and when looking to the aft the cockpit is also very similar. Looks like you have a good buy there.
Boaty😎
Dave Keech
Le gusta a BOATSHED and juskiddin
Help identifying
Hi justkiddin
The hull looks to be an Aerokits Sea Hornet with a difference top.
The transom looks the right shape.
The Sea Hornet was 25 and 1/2 inches long.
Canabus
Le gusta a BOATSHED and juskiddin and
Help identifying
Can anyone help me identify this boat. Bought it in 2nd hand shop has rudder and prop shaft fitted.
Le gusta a BOATSHED
