How to RC small boats?
Iniciado por Ronald
1 reply 5 me gustas 0 seguidores Última actividad: hace 8 años
There's no great need to dismantle a servo to get motive power - nowadays you can buy model motors that are not much thicker than a typical boat propshaft, and speed controllers the size of a thumbnail. Usually for about a pound. These small drones have really helped in this regard. This one, for instance, is 0.6cm diameter by 1.5cm long - https://www.ebay.co.uk/itm/Original-JJRC-H20-RC-Drone-H20-08-CW-Motor-Spare-Part-For-JJRC-H20-08-RC-He-M4S2/332826605276?hash=item4d7e02f6dc:g:7AIAAOSw989bsxkP:rk:39:pf:0
Your biggest problem will usually be rudder control - there will be little room for a servo and tiller right at the stern of small boats. For an EeZeBilt I recommend a closed loop system which lets you relocate the servo anywhere convenient - see http://eezebilt.tk/radio.html The EeZeBilt Terrier below is 10.75 inches long...
Le gusta a Inkoust and Rookysailor and
http://www.mhsd.org/model/howto/servo.htm
Anyone done this? Please send me some pictures of your work and anything I should be cautious about when putting this in a small craft?
I want to put a small motor in the Comet sailboat and run it with the sails furrowed.
