restoration Info on crash tender
Iniciado por wilson
4 replies 0 me gustas 0 seguidores Última actividad: hace 15 años
hI Dave
it did have Ic engine but there is no gunge and the boat is sound it was better kept on the inside than the out side
if have found a plan for the aerokit tender and have found some part numbers inside the boat and they are the same as the plan
thank you
les
les
HI les
Yes looks like an Aerokits model. Did it have an Ic engine fitted, usually means lots of gungy stuff inside and a pretty mangled propshaft and tube. There are several posts on this site detailing how others restored their models, including details of masts. it is usually a good idea to cover the outside of the wooden hull with tissue or glass cloth finished with resin to keep the water out. A good coat of sanding sealer inside should protect the wood from moisture - they are quite wet boats! Good luck with the restoration, but do have a look at the many posts on this site to avoid any mistakes.
HI Dave
thanks for the reply I have been rubing down the boat and found some part numbers on it and 1 now have a set of plans for the aerokits tender and the nubers match the plan so I think it could be one of these I have totaly striped the boat now I have got all the white metal fittings
from modle slipway the only part I have no plan for is the mast any help greatfull
thank you
les
les
HI les
Welcome to the site. The original makers of the RAF Crash Tenders were Aerokits in the early 1960's (approx). Several other suppliers have been on the scene since so it would help if you could provide a picture of your model to help with identification. There are many pictures of Crash Tenders on this site and lots of details and pictures of models both during and after restoration so you should be able to find what you require.
Good luck with the restoration, and looking forward to seeing some pictures.
hi
I have come across a RAF Crash Tender and have started the restoration the boat Is 35 1/4 Inch long I would like to date this model and know what company made them
and If any body had any pic's of them
thank you
les
les
