propshafts lubrications
Iniciado por Maurice
5 replies 22 me gustas Última actividad: hace 2 años
propshafts lubrications . . . and other concerns
Hello friends,
Once again small branches have blown into the water at our “pond”.
Saturday, I was at the pond with my grandson and two boats had wooden parts wedged in and the drive shaft was slightly bent . .
Cutters Aline and Michelle (Commodore Graupner) now have to go to the shipyard!
The “Reine des Vent” is also finished and is waiting for a braided sail rope!
And I wanted so much to continue working on the Mississippi steamer; well, what the heck!
I'm retired ... and you have a lot of time on your hands if you're not married to a vacation technician like she!!!
I love my wife and that makes it even harder for me.
Greetings from a crazy hobbyist, your Michel-C.
Le gusta a Len1 and AlessandroSPQR and
When I build my Shaft Tubes, I make a 1" long oil tube at r
The front of the tubes and once per year I add 15 to 20 drops of 80-90 Gear Oil to the tube.
Le gusta a Len1 and hermank and
I just happen to have one of my boats opened right behind me so I took a photo of the "oiling tube". (I usually make my own prop shafts and tubes.)
The easiest way (with copper/brass tubing) is to drill a hole in the tube where the fill chamber is, and solder a short fill tube to it. I also make a cap to protect the lube from contamination.
As for the lube, I have used various type of greases and heavy oils. I found the best (and environmentally safe) way is to use petroleum jelly. Safe enough for skin wounds and gooey enough to work well in the stuffing box).
Florida 😎, USA
Le gusta a Peejay and Len1 and
Hi Maurice,
Dies war vor 6 Jahren . . .bist Du noch dabei??
Gruss Michel-C.
Le gusta a hermank
Easiest way is to have your tube fitted with an 'oiler tube'.
Hi Guys, I just would like to enquire what s the easiest way to lubricate (fill) propshafts for a tug scale 1:40 ,meaning 10mm tube and 4mm rod.
thanks for your help
😊 Maurice
