Zyx drives v shottel!!!!
Iniciado por green72west
1 reply 0 me gustas 0 seguidores Última actividad: hace 8 años
Hi, wasn't intended to be negative, just to clarify the situation, which you now have. Z-Drive are not my words, but those of Mr Becker who invented it and founded the company called Schottel. I simply found it most odd that you proposed attacking the keel itself.
Thanks for replying RNinmunich. I know the
Difference between schottel and voith prop.
I pointed out in post i wanted to use
In your words "z drives" on my model iO am
attempting to build. I am new to this so give
me a chance to learn without some negative
remarks!!! OK. I will take your advice and
will leave hull alone. I could do with advice from
Members of installation of "z drives" in Bow of the hull. Thanks GREEN.
R.SHAW
