Mahogany in Scale
Mahogany in Scale
No I didn't know there was a premium on ED stuff!
Will have to start touring the Flohmärkte here (Flea Markets - have never heard of a 'Kofferraum Sale (Boot Sale😉) here.
Dimly remember drooling over ED engine ads, way out of my range back then🤔 Didn't know they did RC kit til it popped up here.
Sorry to dash your hopes but Unfortunately I only have the info and not the stuff itself😭
Here are the links
http://www.modelenginenews.org/cardfile/ed_radios.html
http://www.modelenginenews.org/cardfile/ed_radios.html#3
Happy browsing / reminiscing 👍 Cheers, Doug😎
Mahogany in Scale
Onetenor, there is the MPBA, although no doubt it sticks to its Power Boat aspect.
I'm not one for starting stuff any more. Bin dare, dun dat, thanks.
Mahogany in Scale
The British Maritime Museum has loads of models too
Mahogany in Scale
Mahogany in Scale
Mahogany in Scale
Mahogany in Scale
History of RC, RC cars, boats and aircraft. Materials, tools, etc. Mags and books, that kind of thing.
Mahogany in Scale
https://www.google.com/search?q=Model+museums&ie=utf-8&oe=utf-8&client=firefox-b
https://www.rmg.co.uk/discover/museum-collections/worlds-largest-ship-model-collection
A lot are Model Railway Museums but there are many model ship museums and others as well.
Haven't found a pure Woodie museum yet though 😁
Happy hunting
Doug
Mahogany in Scale
Mahogany in Scale
Sure there are Martin, thousands, all over the world.
This is just one in the south of England
https://www.wikiwand.com/en/Brighton_Toy_and_Model_Museum
Mahogany in Scale
That E.D. RC set should be in a museum, but there ain't no model museums.
Mahogany in Scale
"The transmitter used two vacuum tubes wired as a multi-vibrator with a tank circuit to constrain emissions to somewhere near the 27 M/cs band (same as MHz, but that name came later). With not a crystal in sight, transmitter frequency drift and battery voltage drain was a problem, so careful tuning just prior to short flights was the order of the day."
Mahogany in Scale
I can't imagine flying an aerobatic schedule with it.
Mahogany in Scale
Mahogany in Scale
If the IC engine is an easy runner, Colin, run it on a water where the turds can't stop you. A navigable river or canal or just run the bugger till someone can prove (PROVE, mind) that you can't. Then just run it till the fuel runs out, reluctantly apologise and leave.
BTW, I won't be showing video of this as I have no mobile phone beyond an emergency one that don't do pictures of any kind. I have a video camera somewhere that has dead batteries and a power pack, but where I sail there ain't no power!
Doug, would the ED aerial be more like 27 meg if it was 6 foot long? I think it gets damned close to his ceiling if you try to put it up at home.
So, chaps, Sea Hornet/Chris-Craft Special Runabout over on the Build blog section ifn you'm interested.
Mahogany in Scale
Martin: "plus a 22 1/2 volt, the same size as a PP3. Not sure what you'd do for that!" - 3 LiPo 2S (7.4V) in series should do the trick 👍 Or 2 x 3S (11.1V) or a 6S if you can find one!
8ft aerial! if a full wave antenna that puts the operating frequency at about 120MHz. if, as more likely, it's a 1/2 or 1/4 wave antenna it would be 60 or 30MHz. The latter being most probable.
Mahogany in Scale
Mahogany in Scale
It has an 8 foot aerial and stands on the ground while he has a hand set wired to it.
Doug could get that going. T
They say you can't get the batteries, but a box of ten PP3s is a 90 volt battery. That's what my old REP set had, plus a 22 1/2 volt, the same size as a PP3. Not sure what you'd do for that!
Mahogany in Scale
Mahogany in Scale
Mahogany in Scale
Mahogany in Scale
I've just epoxied my Sea Hornet, which I'm modifying as a Chris Craft Custom Runabout. One cockpit, big hatch. Cost me 99p off ebay a few years ago. I just had to scrape all the old red paint off it as it wanted to fall off anyway! Then a huge rub down, a wipe with cellulose thinner and a coat of epoxy applied with a square of styrene sheet because I couldn't find an old credit card on the quick, just as good though.
Next, rub down and 2 coats of cellulose primer surfacer, then the top coats. This one is to be one of the painted CCs. There were quite a few. But the deck will be veneered in the correct style and varnished.
Mahogany in Scale
Mahogany in Scale
Some useful addresses in the back. That's about it.
Nothing on deck fittings, etc.
Mahogany in Scale
I shall review it when I've been through it.
Le gusta a
Cargando…
