Southampton Tug Boat
Iniciado por Weedman
2 replies 2 me gustas Última actividad: hace 7 meses
Remove all deck fittings, vents, hydrants, bollards and bits, as screws are concealed under these, carefully save all screws and remember to replace and tighten them in a uniform order ! The boat deck and hull are sealed together with a rubber seal and grease gently go around the join with a flat tool like a putty knife and gently ease the two apart equally. Watch out for grease, can be messy !😠
Alan
I assume you have moved on from the above.
How did it go?
Cheers.
NPJ
NPJ
Le gusta a doghouse
Can anyone help especially with step by step instructions. Better still, by sending me a video something similar to that which has been seen on YouTube. There is one about upgrading but that showed the deck already removed.
I need help with dismantling the Hobby Engine Southampton Tug Boat which I purchased today. I want first to remove the deck without damaging any part, naturally. I know the removal of screws is necessary all around the deck but for some reason this dose not release the deck unless, it is secured with glue or am I missing something?
Then, I can remove all RC equipment replacing it with my own. Lastly, I want to upgrade the battery from the standard 6 cell AA 800mAh 7.2v to a 1800mAh 7.4v or even a 3000mAh Lipo which will probably have to be relocated.
All help, advice or suggestions would be appreciated. Keep it clean. Thank you.
Le gusta a Ballast
