12T v 13T
Iniciado por titfa
2 replies 0 me gustas 0 seguidores Última actividad: hace 16 años
model boats
HI Alfie Hope you get A life boat e bay best bet but try to see before you buy i bought few dudes take your time most modellers are honest guys but you get dodgy ones dont pay to much get 2.4 radio gear with it dont buy old 27mhz stuff its no good today 2.4 ghz is amazing not expensive new i just buy the boat add new radio gear . Alan
12T v 13T
Hi,
I've got a probe 12 esc with a 13 turn motor.7.2v p/pack
as supplied by a model shop.
Now for my problem, yes you've guesed, It keeps stopping.
it's a brushed motor etronics sport tuned 13t, direct drive with a 35mm 2 blade prop, now, holding the boat In the water I get 4.7amps full forward and 9.3amps on half speed.
a probe 12 has a 12t max, would 1turn make that much difference?
I'm not a speed freak I just like gentle boating with gentle problems.
even on a slow run It stops then I just let It sit and It's off again for another couple of mins,
this esc Is rated at full forward current of 46a,
reverse current of 30a, so It should be able to handle It In any direction, shouldn't It?
sorry the boats a 34inch crash tender, I had the original 3 blade prop on It at first as I thought It was that.
can any one guide me In the right direction? as my home Is a narrowboat on a marina and all this water and sunshine Is driving me nuts.
THANKS SHIPMATES.
