miskin clamps
Iniciado por BigAlio
6 replies 7 me gustas 0 seguidores Última actividad: hace 9 años
miskin clamps
I agree with KMBCSecretary. I have a biscuit tin full with all sizes of Bulldog clips, they are readily available and are not priced up in the sky like some small tools sold for specific hobbies. if you find the grip to be too tight just bend them with a pair of pliers, I am making HMS Alfred Admiralty style and have not had any issues. Good luck. Get the micro-marks catalogue, you will find all kinds of treasures!! Have a super day. Mark.
miskin clamps
Cheers Dave thanks for info always good to get help and information from other fellow builders.
Le gusta a SelwynWilliams
miskin clamps
You can get them from the USA
https://www.micromark.com/mini-hand-tools/clamps?page=3
Part SKU:60926. $20.95. They are on back order at present.
Neat idea using a fine screw attached to the red knob which pushes a plate to hold the plank.
If you can't wait then two bits of wood, one the same thickness as the plank, and a fine screw would do the same. if you drill a fine hole in the former a drawing pin would be just as good.
I like the bulldog clips with a paper clip(?) idea as there is no need to drill holes, brilliant!
Le gusta a reilly4 and BigAlio
miskin clamps
I use the small bull dog clips for planking like this pic cheap as chips and never failed me yet
Le gusta a Ronald and BigAlio and
miskin clamps
Hi guys I was checking out a build log of a Mantua Bruma on www.rcgroups.com/forums/showthread.php?1243658-Mantua-Bruma-Build-Log. he is using miskin clamps does anyone know were it can get some they look a good bit of kit maybe somone out there could recommend something else on a similar idea, cheers
