HMS HOOD by Trumpeter
Iniciado por cormorant
84 replies 112 me gustas Última actividad: hace 8 años
#85
Hi Joburg,
Nice town, long time since I was there, '87 😲 bet it's changed a bit!
A Great Aunt of mine used to live there then.
Re viewing pics; are you using a PC / laptop or a so-called Smartphone or tablet?
#84
Hi Guys
As a new member on Model-boats.com, I am wondering how you Fella's are viewing build pics etc. I see no attachments and get no pics?? Grateful advise.
Tertius
#83
Hi Steve,
You did a great job on her! Really like the smokers! fantastic details as well! 👍
"Fair winds calm Seas"
73
Le gusta a cormorant
#82
Looks great, well done, the smokers look terrific 👍👍👍
Very MAJESTIC😉
#81
Launch day has come and gone. Overall I was very pleased with the way she looked on the water, but may I apologise for the quality of the video.
First off, I was unable to get 1/200 scale dragonflies or a moorhen, which somewhat detracted from the realism, but most importantly, my ace photographer Octman was unable to make it.
I promise to do better next time.
I also learned that this is primarily a display model and it is so easy to damage or bend the many tiny parts.
However, she has given me much pleasure both on the slipway and her short time on the water.
Le gusta a Bryan-the-pirate and Rookysailor and
#80
Hi Martin, will continue this on your original 'useless' thread this evening.
#79
Well that's something then, Doug. Any ideas why it won't bind? Could it be that trainer switch as suggested by somebody on here?
#76
Evenink Martin,
Sounds like the old 'shaggy dog story' of the US sending the Russians a drill bit the diameter of a human hair, to show their engineering supremacy!
The Russians supposedly sent it back with a hole drilled in it 😲😁
BTW: first result with your TX!
I knocked up a simple diode RF detector, connected to Dad's vintage AVO Minor (2.5mA range) and your TX is certainly transmitting SOMETHING!
Now to try and find out WHAT 😉
#75
Doug, Albion Alloys do as small as 0.3mm TUBE and wire to go in it. I've used it for working model piano hinge! Albion sell to dealers from whom you must buy. They don't sell direct.
#74
Thank you Ed and Doug - I must admit to feeling a little pleased with myself.
The rod is manufactured by www.albionalloys.co.uk/.
I discovered it at my local model railway shop, which carries quite a few useful bits and pieces for model boats.
Sea trials planned for later this week or early next. Hopefully Octman will be ready with his camera to video the event.
Steve
Le gusta a RNinMunich and figtree7nts
#73
Brilliant! 👍Antenna looks really realistic, an' I've seen enough 'in real' 😉Where on earth does one get 0.45mm nickel silver 'rod'?
Detailing and painting Veeery impressive as well.
Sea Trials soon???
Well done that man!
#72
Hi Steve,
Looks great, I like all that detail!
Must be very time consuming.
But in the end looks awesome!
73
#71
Almost at he end of what has been a long, sometimes frustrating, but very satisfying build.
As the masts and spars are very thin, using my usual fishing line as rigging was going to cause problems with getting anything like the correct tension.
What I ended up with was 0.45mm nickel silver rod. The fineness of the rod gave it a natural 'sag' for radio aerials and it is rigid enough for stays and supports.
Hope someone finds this useful.
Steve
Le gusta a reilly4 and RNinMunich and
#70
Hi Peter
If you look at this website http://www.hmshood.com/hoodtoday/models/trumpeter/trumpeter200.htm
you will see that there are enough incorrect items to drive you mad. I have decided to get it as accurate as the kit allows.
I have installed a Graupner 6v smoke generator in each funnel with a computer fan at the base of each - yet to be tested. I propose to switch them on and off with a receiver controlled switch.
I would like to be able to colour the smoke but have yet to find the correct formula.
Steve
Le gusta a Rookysailor and RNinMunich
#69
Even tastier with the Frankfurters, and Colemans Mustard I trust😜😋
Steve: I found a cheap way to mechanise the two aft turrets of my H class destroyer Hotspur, using one servo with a pulley, a couple of smaller pulleys on the turrets, about 2:1 ratio to give at least 180° rotation at the turrets, and a spring loaded nylon cord around the pulleys. I'll see if I can dismantle her over the weekend to make some pics. I plan to try something similar with my 1:350 Hood, also Trumpeter and also excellent detailing.
Another way is to use one micro servo per turret, connected with Y cables if you want a synchronised Broadside; A+B and X+Y turret. Then use the servo travel adjustment at the TX to maximise the rotation.
You can then move all four on one channel or two channels for 'Independent Firing" fore and aft. I will use the two pots at the top of the Turnigy i6 TX for this. On Hotspur I used the left stick left/right.
I plan to do this in my Graf Spee, Belfast, Hood and Bismarck. Maybe also the ack ack turrets on Ark Royal!?
Will knock up some test jigs sometime 🤓
Cheers Doug 😎
#68
Hi Steve, looking very tasty with the wood on now, have you a thought on the funnels, been informed that the rear funnels is incorrect, but you can get an aftermarket one, just another thought on the smoke theory, wonder if one of the smoking gizmos from the 1/16 r/c tanks could be an option, I wonder if Doug has a thought on this.
regards,😊 Peter
#67
Hi Steve,
She's coming out very nice!
Great detail can't wait to see the sea trails video...
73
#66
For those of you who have never built a Trumpeter kit, I can strongly recommend it. Although Hood is 1/200 scale, the detail is fantastic and an awful lot is fitted into the 1.2m length of the model.
I think a wooden deck is a must, together with an upgrade kit for the guns, giving them metal barrels etc. I'm not sure if the more expensive upgrades are worth it as there is so much provided in the kit, including a lot of photo etch.
I tried to mechanise the main turrets but found it beyond my skills, so I am now concentrating on the finer detail.
I have at last managed to obtain the 2kg of lead which I estimate is required for ballast. (I calculated this very scientifically by floating the hull in the bath and using a 1.5kg jar of frankfurters).
Sea trials are planned for the middle of next week.
The attached images show progress so far.
Le gusta a dickylew and reilly4 and
#65
Hi Peter, Thank you! Happy to help. But I don't claim to know everything😉
I stay out of discussions on things which are not my forte; e.g. yachts and other sailing craft, apart from admiring the woodwork involved, or subs - where I am still at the bottom of the learning curve, but I've been a fan of WW2 warships for years and enjoy researching the history and building them.
Been fiddlin' with computers since the end of the sixties! They got a lot smaller since then 😁
I envy you being able to visit the Heywood show 😡
Sorry the 'Extra Time' site has been deleted by FIFA (I couldn't afford the million 'Fee' they wanted😁) Happy building and sailing, cheers Doug 😎
#64
Great Doug, it's fantastic to think any problem your just a mouse click to solve to problem, many thanks.
Could you please supply the link to purchase that 'big box of Extra time' you mentioned.😊
Off to the show at Heywood mutual boating club tomorrow, to see if there are any bargains to be had.
regards, Peter
#63
Hi Peter, you're not doing anything wrong at all👍
When I analyse the element (look at the code behind the display😉) the link is three lines long.
It's just shortened in the post display. Just depends on how much space is made available to show it, esp the width of the box. if I scrunch up the code display the link is shown with even more lines .
The address box in your browser is limited so it can't display all of a long link. But if you press the 'END' key the display jumps to the end of long links 😲 Cheers Doug 😎
#62
Hi Doug, how strange, the link when I first put it on was three lines long, just had a look now, and it looks and works fine,
maybe I need some time and lessons on I T.
Peter
#60
Hi Peter, some links JUST ARE THAT LONG, some even longer, and you need the whole thing to get where you want to go! it's like route instructions from A to B 😉 PM me the whole link. Doug 😎
PS Glad to hear your wood arrived👍 Now just order a big box of 'Extra Time' 😁
#59
Many thanks Doug for the info. itried to send Steve a link to an item on Ebay using the actions you have explained, but for some reason the link was 2 lines long, I will try and send you the same link and see if you can solve the problem
merci Peter🤓
#58
Hi Steve, Had a nice surprise this morning,😊 wooden deck finally arrived, box damaged (bent slightly) but no damage to the decks or Chain!!!now just gotta find time to start the build.
regards, Peter
#57
Hi Steve, Chris,
No Chris yours wasn't the thread I was thinking of but this
https://model-boats.com/search/Hobby-Engine-Richardson-Upgrade
Same model just a different name.
The transducer idea was sparked off I think by a video of 'Noisy Thing' in an RAF launch - by PMDEVLIN I think.
If we'd seen your thread we might have said that fitting the transducer horizontally under the deck is not the best idea. That also directs the sound upwards and the deck is too stiff, due to coamings and superstructure etc, to resonate with the transducer.
Recommendation is to fit to the hull on either side, wired in series so that two 4Ohm transducers give the 8Ohm load impedance needed by most amps.
The idea is to bring the hull sides to vibrate thus acting as a 'speaker cone' and project the sound sideways across the water and not straight up. They should be fitted to the largest flattish area available for maximum effect.
I like the 'sound-palettes' idea 👍 Let us know how it goes, Doug 😎
#56
Yes I was that person with the transducer( amongst others). I originally had a speaker inside the lower superstructure of the tug, where there are window openings, but without any glazing, so in theory the sound should have been able to escape. The engine sounds were OK but the other sounds, on a different sound module, were only audible if the model was more or less within arms length, which I thought unsatisfactory! Aha I thought, use a transducer attached under the deck, other people seem to get satisfactory results. I didn't. I think that there is too much clutter on the deck of the Southampton,which is not that big, preventing the hull from doing what it is supposed to do. Next idea is to conceal a normal speaker on the deck disguised as a pile of pallets, with lots of lovely gaps to let the sound out.
#55
Had thought you were too! Your 'sound grating' looks fine 👍
On my destroyer (1/72) I have an oval speaker, about 4 x 2" under the aft torpedo mount. Cut the deck out leaving just a cross in the middle to support the mount (which ain't bin built yet🤔) and covered it with aircraft fabric and painted. With a 10W amp it's OK close to shore but out in the middle, ca 50yards, almost inaudible - especially against the row of the Biergarten behind me! Doug 😎
#54
I thought you were going to bed!
Hadn't thought about transducers, but Octman has a Southampton tug and he fitted them, to no effect. May be the same discussion. I'll ask him. Thanks for the tip.
I have the same sound system in my Sovereignty and I put the 4" speaker under the compass platform. I then drilled many small holes in the deck, which sounds terrible, but doesn't look amiss (even better with the 'monsoon roof' on) and works well.
Steve
#53
"The other complication is that I also want to use the funnels to let the sound out for my Shockwave2 sound system."
Hmmm! Hope the birdies enjoy the sound! Cos it'll just go straight up🤔
If I can fit 'em in I will try the little transducers stuck to the inside of the hull, to use the hull side as a sound board to send the sound sideways across the water and not up into the sky.
There was a discussion here about these a while ago wrt a Southampton tug upgrade! Doug 😎
#52
Me too! G'night😉
Yes, you're right about the 'falling', as soon as it starts to cool.
If you use it a lot you will start to notice an oily film on your upper works 🤔
#51
Hi Doug.
I'm very much the novice with smoke so although the 6v gives enough for one funnel, a fan may be necessary. Real smoke rises of course and I didn't realise that the generated stuff falls as well.
There is enough room in the funnel, but as you say, no updraft.
All good fun.
Going to bed now.
Steve
#50
Hi Peter, Re Link posting:
Open the site you want to link, e.g. this one!
https://model-boats.com/forum/building-related/38869?t=1521853430
Left click on the web address shown at the top so that it is highlighted,
Press 'Ctrl' and 'C' together to copy the link,
Go to your post and put the cursor where you want to add the link address,
Press Ctrl and 'V' together to insert the link you just copied.
Bon chance mon ami, 😎
#49
Hi Steve,
with the 'reservoir' I mentioned I meant a 'smoke reservoir' or a sort of collector, i.e. a wider section of the updraught tube, bulbous or upside-down funnel, to concentrate the smoke and then 'chuff' it out with the fan.
Seems the modern versions of the Graupner gennys are very different from the one I bought 20 years ago!
Mine has a narrow glass tube underneath which dips into the aerosol cap oil tank and feeds the genny by capillary action. Means it last for ages (well all afternoon anyway😉) on a 'tank' full. As I understand it the maximum fill (0.8ml) of the new one lasts about 8 minutes at 6V / 300mA.
I have some of the new ones now and see what you mean by 'charging' from above. But, how do you propose to fit it? if it's a tight flush fit in the tube won't you lose the updraught chimney effect cos it can't draw cold air in around the genny tube?
Yep, the 24V put me off as well. Rooky mentioned using a voltage 'booster' (i.e. doubler) but these are notoriously inefficient and if you're running on 7.2 or 7.4 main batt .....!?
Just my thoughts, must experiment with the new versions.
BTW: my static bench tests back then were also quite impressive, stunk the kitchen out 😡, but out in the open air with a bit of breeze or under way at speed it didn't look quite the same 🤔
Be interesting to compare notes when we both have them operational!
Re 'Morse message': had hoped that an ex navy guy like Ed could decode it 👍 Cheers Doug 😎
BTW: your funnel construction and painting looks terrific 👍
#48
Hi Peter.
Sorry to hear about the non arrival of your deck. I must say that I am very pleased with the way mine fits and looks - I have done all bar the 'rear deck' and as I said, provided you start off accurately, the rest follows.
Please see the post above which I sent to Doug. I hope I have solved the smoke generator issue.
Steve
#47
Hi Doug. Fitted 6v genny into funnel which I can charge using the syringe through the top - therefore, no reservoir required!
Bench test suggested no fan required though picture doesn't do it justice.
I'm quite pleased with the effect so will order another 6v for the second funnel. I propose to switch them on and off with an Rx controlled with from HobbyKing.
Pity that the 'smoke' is not darker in colour - there must be someone out there that has solved the problem?
I've had a look at the link you sent. I see they need 24v and are quite expensive.
I also se that Ed (Figtree7nts) has been in touch re morse 'message'.
Cheers. Steve
Le gusta a RNinMunich and figtree7nts and
#46
Hi Doug, Have just sent a message to steve, and wanted to post a link from a website, can you assist in how do I do it
Danke Peter
Le gusta a octman
#45
Hi Steve, decks still not arrived, have sent an email will see what happens. Doug mention the smoke maker from Marks Model Bits, I have one in a tid tug OK for a 1/32 boat but too big for Hood, the theory is using a nebuliser to agitate the water molecules to make a mist (steam)I now get mine from https://www.ebay.co.uk/itm/New Ultrasonic Mist Maker Fogger Water Fountain Atomizer Air Humidifier 24V.
Hope I got the link correct. it is powered by 24v but you can use a voltage booster to get 24v from 12v, and you could make it fit in the hull with your own design water tank.
cheers Peter
#44
Mornin' Steve, that's exactly what I intend to do, 👍 but with a fan I can switch on/off remotely just to see what happens, or doesn't as the case may be 😉
Bench test of such a system is somewhere in the bottom third of my To do / To Try list. So many ideas - so little time 😲
Whatever, it's fun finding out ain' it?
I've also been wondering about the new generation of oil-less generators, such as
http://www.marksmodelbits.com/
Cheers Doug 😎
#43
Hi Doug. Not very successful then. What about a 6v one in each funnel? They don't need reservoirs and I could charge them with fluid through the top of the funnels using the provided syringe.
Steve
#42
Sorry for the digression Steve 🤔
Re your smoke generator -
I hope you don't want to lay a smoke screen!
Several years ago I fitted a Graupner smoke genny to my destroyer and hoped to feed both funnels with it. No way! 🤔
According to instructions I fitted it in a 10mm tube (alu) in the forward funnel, with the wick in a 'tank' made from a large aerosol cap, and fed it from the drive battery (12V SLA, 2 x 6V 7AH) via the Gear switch on the TX and a home made decoder / relay switch at the business end.
First: it takes a little while to get 'steam up', second at best it produces whisps of smoke, and white so it looks more like steam. 🤔
Have experimented with 'additives', e.g. graphite, but have not yet achieved real black smoke.
To increase volume when I refit the destroyer I have a second genny for the aft funnel and intend to build 'smoke reservoirs' under the funnel tube and drive it all with a 6v cooling fan from an old PC graphic card.
The 'chimney effect' alone is not enough 🤔
I hope that in this way I can increase the volume so it looks a bit more realistic when 'getting steam up' or on 'Full Ahead Both'!
(Give me all you've got Scotty!)😁
For various other 'mini model' projects, 1/350 Plastic Magic, I have acquired several mini smoke gennys from the model railway (1/87) department - experiments are on the To Do list😉
Cheers Doug 😎
Le gusta a Colin H and Donnieboy
#41
'66 was my first visit to the Reeperbahn, Veeery interestink!😉
Visited the Star Club where the Beatles played. Was highly amused at how many churches were sprinkled amongst the clubs and 'other houses', sin here - repent next door! German efficiency 😁
Your Imbiss guy was very lucky, not many made it after Dorsetshire was warned off by a U-Boat warning 🤔
I've been here 32 years now, see no particular reason to come home after so long! They say 'Home is where the heart is', and my GF is here!😊
Tschüss und auf wieder hören, Doug 😎
Le gusta a Donnieboy
#40
You have aquired some great knowledge Doug, most of all you have kept it, well done.
I was in Hamburg 1967 playing with a band at the Top Ten club on the Reeperbahn (learned a lot there), we used to go to a imbis next door to the club, the owner spoke a little english as I at that time spoke very little German. He told us a bit of his life story, he was on the Bismarck on sinking, he was picked up by the british and took to a pow camp near the Cadbury factory in England. He took a few of us to the B&V yard, and gave us a guided tour very interesting, he was call Fritz and he had a phrase he always used when we spoke of the war ' thats the vay de ball bounces', with a very heavy German accent. I spent many years in Germany and loved every minute of it.
warm regards, Peter😊
Le gusta a Donnieboy and RNinMunich
#39
Thanks Peter 👍 very glad they were helpful.😊
comes from 40 years 'bumming' around the world talking to ship builders and ship drivers! And building a shrewd idea of where to look when I needed info on a new customer requirement.
Trick was to try and stay at least one step ahead 😉 Now I just do it for fun, and still learning a lot myself - just by seeing what U lot are up to 😁
I first visited Hamburg around 1966 on a school exchange trip.
We played the German kids at footie and beat 'em with the same score as in the World Cup that year! 😊
What took you to B+V? All the best, Doug 😎
#38
Your knowledge is boundless Doug I am sure I'm not on my own when I say you have assisted many modelers on this sight with your instant information, the colour sheets you sent are fantastic.👍
I was in Hamburg in the late sixties, and also visited said yards, still very impressive, and spent some time in Kiel.
cheers Peter
#37
Hi Peter, The Bissy was only in the Baltic for running up and training. in Unternehmung Rheinübung, foray into the Atlantic and the Battle in the Iceland Straight (sorry Denmark Straight), she would have had the normal light grey plus possibly camo colours, here, yer pays yer money and ya takes yer choice! 'As built' she would have been all DKM Hellgrau / Silbergrau (Light / Silver grey) #50 (that's the Lifecolor #UA 601) on the slipway. All the docus, vids and photos I have found don't seem to show any significant camo paint!? Only pic I ever found of Bizzy in camouflage paint is of the Graupner Premium model. Can't find any official record of it.
There is some evidence of cammo paint on her sister ship Tirpitz, but it didn't help her, she spent most of her life bottled up in a Norwegian Fjord where she got flattened by Lancs!
Cheers Doug 😎
Re Enamel: Maybe attached charts will help you find an acrylic equivalent😉 I will use the Lifecolor 601for mine.
PS Bismarck had No later life!! One operation, one ship sunk (Hood 😭😭) and that was that! Can heartily recommend the old 1960 Kenneth More film 'Sink The Bismarck' 👍 Stirring stuff Old Chap, stiff upper lip stuff from the days when we still had a real Navy and hadn't swapped our overseas bases for 50 ancient rust bucket WWI destroyers🤔
By the by: during my 32 years working here (in Naval COMMS systems) I was frequently in the Blohm & Voss HQ in Hamburg, saw several superb yard models of their ships including Bismarck, and many photos, but never a one with camouflage.
PPS: as far as i can establish the 'Baltic light grey' was only used on the top sides of smaller U-Boats operating in the relatively shallow Baltic waters. Maybe also a few small combatants such as Schnellboote, Minenjäger etc.
Le gusta a Colin H
#36
Many thanks Doug for the paint info, I notice there are 2 hellgrau
on their lists, one light grey and one Baltic light grey, would that be the colour in later life of the ship? it's a pity that they are enamel paints, where lifecolour are acrylic, could you suggest the colours for my Bismarck.
many thanks again, Peter👍
