Shroud to Turnbuckle
Iniciado por 00Trev
10 replies 21 me gustas 0 seguidores Última actividad: hace 9 años
look forward to hearing your review on the tool. if it's as good as it's meant to be ??
BOATSHED
Le gusta a 00Trev and Dave M
The tool has arrived from Wheelspin. its a bit smaller than I expected but it looks like "it does what it says on the tin".. I'll try it out in a few days when I get a moment.
Le gusta a Dave M and BOATSHED
That is a neat little tool. I see in the video that he was using a soft wire and assume when using a bit of stainless wire for the hook end of the turnbuckle you will need to put the tool in a vice -my fingers are not that strong.
Le gusta a 00Trev and BOATSHED and
But where can you buy one of these. I could use that in both model boats and my fishing tackle. I want one.
BOATSHED
I think I found a tool to do it and wheelspin stock it in the UK..
Du-bro Kwik twist
and this Vid shows how it works...
It looks cool so I ordered one! 😎
Trev
Le gusta a Ronald and Dave M and
Thanks Bryan,
I realise that's the normal quick way.
I've included a picture to see if anyone knows how its done.
It might be (I heard) that the fishing community have a tool to do it?
Trev
HI, on Yachts
Joining the piano wire shroud to the turn buckle...
How do you make the neat loop and coil?
thanks
Trev
