Spraying/hand painting
If you are intending to use this Full PPE equipment should be worn and only use in a well ventilated area.
Personally I use paintstrippers, scapers and a hot air paint stripper to clean wooden hulls back to bare wood. This allows me to see any damage caused by fuels used with IC engines.
I agree its messy, takes time and is best done outside, but you do end up with a solid hull with no hidden soft spots.
I agree with Jarvo's use of Clear Cote either in gloss or semi matt finish.
If the air temp is much below 20 deg most rattle cans will not give a good finish and runs will be difficult to avoid.
It may be available in an aerosol. Please check it out as I find it saves hours of stropping on my old boats, my newest being about 1980, and oldest from 1918. Hope this helps, Colin.
However, it was not the easiest paint to work with and only got a good finish when everything was stripped down to the bare wood. I applied sanding sealer followed by Halfords primer then built up several coats of acrylic , leaving 3 hours between coats. When finished I used rubbing compound to get a good gloss.
I am sure there must be better methods of painting model boats especially vintage ones that have already had coats of paint in the past.😁
Hope this is helpful, cheers Colin.
Cheer's marky
A good idea is to try and make a shelter around the boat and wet it before giving it the final cost of a good quality gloss paint.
It really is just a matter of perseverance and you should have a great finish.
Good luck!
Peter581
Le gusta a
Cargando…
