Paper plans
Paper plans
Most of my plans are on paper but it isn't a problem as I redraw them anyway and so accuracy isn't an issue and I tend to modify them. I like to have the plans for reference for building and it's just nice to have them.
Paper plans
Paper plans
I've folded hundreds, well probably thousands, of building drawings in my lifetime and it's not difficult to do properly, like folding a map.
Better when they are supplied as PDF's and you can get them printed yourself.
Paper plans
I tend to use plans as a reference and transfer straight lines to large paper especially if building on the plans direct, this is possibly essential when building wings and fuselages over the plans and I have also done it with boats, as recent as the veron Vosper RTTL I’m currently building from eBay plans (copies!)
Paper plans
I agree ironing under brown paper and storing in a tube works well.
Paper is not a very stable medium and any plan will likely change slightly due to the moisture content.
To be accurate you need measurements together with a ruler on the plan so that you can make any adjustments.
I have always treated such plans more as guides rather than accurate representations and will adjust the pieces I make to fit.
Shipyards used to employ fitters who did exactly this.
Probably why many recent kits use laser cut parts with plans that show how the bits fit together.
Good plans are not cheap. I bought plans for the Titanic at 1:96 from Dr Haan for about £200. Came on 12 sheets (12' x4') all produced as original line drawings and packaged in a large cardboard tube. The professional photo copies we had done for the frame outlines showed that the process was not 100% accurate and added 0.5mm to some parts.
Paper plans
Doug 😎
Paper plans
Sorry mate, it's not for posting it's for storage.
taffy.😁
Paper plans
Nothing to get excited about. Rather a simple flat envelope in the post than a long (and more expensive to post) tube that won't fit in the postbox.
Cheers Doug 😎
Paper plans
I too have received some plans that have been folded like that, and I have laid them out on a board then place Brown paper over them and ironed them flat before I rolled them and placed them in a Roll folder from the P.O.
taffy
Paper plans
I have received paper plans folded up and the first thing is I roll them and place in a cardboard tube.
The tubes are free from carpet places.
Canabus
Paper plans
I don't have any experience of buying from a shop, but on line (e-bay etc), you buy the plans, they arrive in a nice envelope, but when you get them out they are folded, in what appears to be a random manor, that is bad enough, but now the world has gone technology mad, it would appear that a straight line is not possible without a computer. I thought hobbies like model boats, aircraft etc. Was supposed to be nice and relaxing, then you get a set of plans (which someone has taken the time to draw), with which we plan to build our next model but someone has not been carefull enough to take the time to fold 'nicely'.
Sorry but it annoys me, part of my enjoyment is creating good plans to build from and I hope I can at least present them packaged in a way that looks professional.
Sorry about the rant, just opened another envelope, and the sended could only get it worse by 'cunching' up the plans for the bin.
Le gusta a
Cargando…
