1/35 Vosper MTB
Iniciado por Ronald
7 replies 11 me gustas 0 seguidores Última actividad: hace 9 años
1/35 Vosper MTB
Thanks for ALL your replies. I enjoy reading your suggestions and will take them under advisement as this project goes forward. I have three grandsons 7,5,2 so am not sure when the project will get underway. My first grandson asked me to build a Battleship, and finding the Revell 1/350 USS Missouri recently for $40 CDN this kit maybe built before the Vosper.
See: bmpt.org.uk then "select a boat here" pick "MTB-71"
Does anyone know "Clive Hampton" seen on page 2 along with Peter Baillie ?
Has anyone built a 1/350 USS Missouri and motorized it?
Le gusta a RNinMunich
1/35 Vosper MTB
Doug
This is a project being built with his grandson.
It is perfectly feasible to run with just one engine and use brushed motors and NiMh batteries.
Direct drive would work fine.
Only a small boat so installation need to be kept light.
I do believe when someone asks a question and states a preference it is more helpful to suggest how they can achieve their goal.
Your suggestion about LiPos and brushless miss the point completely.
Le gusta a Ronald
1/35 Vosper MTB
Buy quality LiPos, not no-name cheapos, and follow the rules and they are no problem. The great advantages are higher endurance and lower weight😊 Shame to run an MTB on only one screw🤔 At least two should be fitted or it just won't look RIGHT!
I recently bought Basilsdad's 28" Elco PT Boat. it came fitted with 2 x 28er brushless and he said it was "too fast for me"! I am refitting it as Kennedy's PT109 and will retain the two brushless and fit a LiPo as far aft as possible to help with getting the hull on the plane.
@ Reilly; I think that was ironic humour from Tica 👍 and I hope he continues to offer advice from his experience.
Cheers Doug 😎
Le gusta a marky and Brucef102 and
1/35 Vosper MTB
Hi Tica,
From the question posed it was a sensible proposal. Please don't give up on offering help.
I was not aware that RC gear needed to be set up for brushed motors or otherwise. I use mine for both brushed and brushless applications and I also have electronic ESCs as well as the old variable resistor types.
Le gusta a Skydive130 and RNinMunich
1/35 Vosper MTB
Well I'm sorry that I'd spend time to suggest that you could use high explosives in your boat
1/35 Vosper MTB
All of my motors are brushed alonag with NiMh batteries and chargers. My preference is to use brushed though I am aware that brushless motors take less space as do the batteries. if someone could provide clarity for RC conversion using the single brushed motor, I’d appreciate hearing from you.
1/35 Vosper MTB
I would go for a single Brushless solution 1200-1500KV with a 2S LiPo battery, this will help on the amount of weight you have to add to the model.
1/35 Vosper MTB
I was given this kit to build with my grandsons. Static or conversion? If conversion, could it be done with one prop instead of three? Direct drive or geared?
