1 reply0 me gustas0 seguidoresÚltima actividad: hace 9 años
Tried seabreacher out with new ballast and brushless setup.....Had a nice long walk through the woods to retrieve the model after it beached itself on the other side of the waterway...😱😱😱
Just spent a few hours fitting brushless motor to seabreacher....and 150amp esc ...problem working at these high motor speeds is vibration and motor has actually bent the driveshaft which is brass 6 mm ...next step is new shaft of steel....
