Sea Rover detail wanted
Iniciado por dbninja
6 replies 0 me gustas 0 seguidores Última actividad: hace 16 años
I plotted bulkhead shapes from a Lesro plan - and made card templates.
See the start of my build from balsa - not yet completed due to family circumstances and other commitments...
[url=http://s65.photobucket.com/albums/h229/keven64/Sea%20Rover/]set 1[/url], [url=http://s65.photobucket.com/albums/h229/keven64/Sea%20Rover%202/]set 2[/url], [url=http://s65.photobucket.com/albums/h229/keven64/Sea%20Rover%203/]set 3[/url]
Keven. 😊
If bulkhead shapes/dimensions become available I would be very interested. Can they be posted on the site? I have the Lesro plans and would like to have a go at a Sea Rover but the bulkhead shapes are a real problem, particularly because the hull sides are not necessarily straight lines. The transom, in particular, is definitely curved.
hi
welcome to fireboat... I intend stripping and replacing the deck on mine when I do the rebuild so I could take a few measurements of the hull formers while it is off if thats any help
I have sent you a private message
David
I have aquired a Sea Rover plan. Anybody able to help out with bulkhead shapes and instructions
Hi,
I think you will find that you can buy plans from Lesro at christchurch. They have plans for most of the old aerokits
models. Hope that helps. Regards
All
has anyone got the plans to the Aerokits Sea Rover (the one with the covered rear deck)
I need a copy of the part of the plan that gives details of the rear deck cover so I can reconstruct It on mine
drop me a pm If you can help
thanks
David
