Sail control
Seguidores (1)
If you take the back off of your transmitter and operate this stick to identify which one it is, you may find that it has a friction adjuster that can be tightened if you think it moves too freely?
Tout juste de retour d'un périple, je te souhaite moi aussi la bienvenue !
J'espère que tu trouveras ce que tu cherches ; ici, on s'entraide avec des conseils et des idées géniales. Après, ce que tu en fais, c'est ton affaire ! En tout cas, les expériences que j'ai pu lire ici m'ont été d'une grande aide. Pour moi, c'est le meilleur site pour les bricoleurs !
Michel-Cl.
I’ve just returned from a trip, and I’d like to extend a warm welcome to you as well!
I hope you find exactly what you’re looking for here! We support one another by sharing advice and great ideas—though, of course, it’s entirely up to you how you choose to use them! Personally, the accounts and experiences shared by others here have been incredibly helpful to me. In my view, this is the best site for anyone who enjoys crafting!
It would be better to add this function to a stick unit that has a ratchet on it - this is usually the left hand stick on a mode 2 transmitter.
Most Mode 2 RadioLink transmitters come with a ratchet on this stick unit in the forwards and reverse (up and down) movement - something that I always have to change when I buy a new transmitter as I prefer my throttle stick to be self-centring.
If your left hand stick unit does not have a ratchet on it, check to see if the other stick unit has a ratchet on it as your tx may be a Mode 1 transmitter, in which case the ratchet can be moved to the left hand stick unit and the return spring can be added to the right hand unit.
Adding or changing a spring or a ratchet to any stick unit is very simple and obvious once the back of the transmitter case has been removed to reveal the way the sticks work when they are moved.
If all your stick units are self centring, then maybe the previous owner has already removed the ratchet.?
Replacement ratchets (or springs) can be bought online if needed.
The overall construction of the sail control system is nearing completion and I should be able top post some pictures in the next couple of weeks.
You can also try the Amazon official RadioLink site for your spare parts etc.
From what I can see, it looks like it is linked to the RadioLink factory, but sold through Amazon.
Prices are higher than AliExpress but it is another source that may be of interest to you.
https://www.google.com/aclk?sa=L&ai=DChsSEwiU7vj0kqWXAxXJl1AGHeGpCmwYACICCAEQIBoCZGc&co=1&gclid=Cj0KCQjwuJLWBhD_ARIsAIBcRUxLLOZoATFfq3ROZZlnlmEVg4E_xR_JZIW1G1E-YhJjqp4f5Y1IY9YaAhIEEALw_wcB&cid=CAASsAHkaDOmJUKmjt8SA-sSUA5cQwakbgZSHYWFPbyNJBGQnyVVdP1C7APGS3MrYRhKo-Lcw-WD7qGW6LCLLumjiROpP6jWU8zpvmSRQi8sDhVLrRu1j3PcbCpdkuf6HrYswbtjk91gYKQUjylTuzz6EHkcSInS0Ow-woLCIYnpnn1454gQ9ukD2sRecLGlsglzvJqIMK3jfs0faH3v82IUSlJAKhx0EQtxv8vTFcgDWHO1nQ&cce=1&sig=AOD64_1xAMpmqMWkSUo20o0-dTxPTHn4xw&q&adurl&ved=2ahUKEwjqovL0kqWXAxU1Q0EAHYPNH8oQ0Qx6BAgbEAE
Hi Henry,
The SBUS socket is something that can be used to connect an electronics board that gives various functions for use on r/c tanks etc, but it is not used for regular connection to your servos.
I use the SBUS connection with my r/c tanks, but can think of no use for it on your r/c yacht.
Choose the receiver socket to match the required stick when you plug in your steering servo and your sail servo.
Usually the left hand stick with the up and down movement for your sail winch (or throttle if you use it on a power boat), and the right hand stick with the left and right movement for your rudder (this would be the same for a power boat rudder).
The only other socket you will probably use on your yacht is the battery socket to plug your on/off switch into.
Forget the SBUS socket - you have no use for it with your yacht.
Hi Henry,
I think my radio is a RadioLink AT9S, and an AT10, but I will check when I get home.
You can buy anything that you need for your RadioLink set online from China at good prices and fast delivery.
I use Ali Express as they usually have everything available including replacement transmitter cases and battery box covers (!) as well as the usual spare receivers, transmitters, aerials and neck straps etc.
You can also check the new radios that are the same as yours to see what receiver they usually come paired with - although you can bind almost any RadioLink receiver to almost any RadioLink transmitter.
Check-out the RadioLink site to see the full instruction handbook for your particular model.
I do need to get some additional bits such as a battery pack, switches and connectors for the actual installation in the boat, so trying to find a supplier here in France, preferably near me.
When I am home next I will take a picture of it (and the receiver) to confirm they are the same as yours .
The supplied (or not in my case!) Chinglish instructions are not too good, but I found some online instructions for my RadioLink transmitter (on RadioLinks own site) that are a little clearer and easier to understand.
The truth is that you don’t need to know even half of what the instruction book advises unless you decide at a later date to fly r/c helicopters, or 3D aerobatic aircraft or V tail soaring gliders - all of which can make some use of the custom mixing programmes that you have no use of on your yacht.
If you have the same receiver as me, then it already has two aerial wires coming out of it.
If you do, then simply route one at 90 degrees to the other to get your best signal.
Nice and simple, not extra ariel wires needed.
Bob,.
ALI EXPRESS or TEMU
easy to do here, cheap, and fairly fast delivery. I got bags of them, knowing what I was getting into when building the model
Also these: for attaching jibs to fore stays. (FORE STAYS: also known as STAINLESS STEEL PLASTIC COATED FISHING LINE)
No one said this was going to be easy! Thanks to all who read this for the help and advice.
I have Hitec stick transmitters, some of which are more than 8 channels, but whilst more complicated do tend to offer more adjustment which I used on one of my yachts which gave greater sheet travel than I could get with one of my simpler transmitters. Currently I'm only using 2 channels on my builds despite the Tx having so many. This of course is due to us having to use Tx designed for aircraft mainly.
It may be worthwhile sticking with what you have and trying to find out what you need to know. Others and myself may be able to help along with Google searches.
Hi Henri, I’m really glad you found the right solution for the jib and mainsail control system.
Just recently, we were discussing these issues with RossM (I’m including the link at the end so you can take a look if you like).
I hadn't remembered that you had discussed this too, but your latest message brought it back to mind.
From the photos I’ve seen, I believe you’re using the same system Gary Webb used. It’s a highly functional and well-proven setup, especially if the rudder is doing its job well.
Once you’ve successfully finished the build, I’d be very happy if you posted the photos and a description in that thread as well.
Keep up the good work.
https://model-boats.com/forum/170050
I think I have an over-complicated radio control (a Radiolink T8FB with 8 channels!). The instructions are in loosely translated Chinese and full of acronyms and I'm really struggling with the whole set up at the moment. I am very much a mechanical engineer and not really into wiggly amps, so I might sell it on and look for a simpler 3 channel unit.
When I have the sail control system set put together I will post some pics.
Henri
Frustratingly when I was looking for a winch servo most manufacturers don't seem to provide essential information like turns and maximum sheet travel etc. Fortunately a friend building a yacht was able to help me.
H
H
https://www.radiosailing.co.uk/dragonforce-65-boat-spares-187-c.asp
Thanks again for the help and advice. This boat has been a long time in the planning and is still going slow as is my restoration of a Triumph GT6.
For a winch system which is previously described and they work well, elastic is needed to keep the tension on the cord that goes around the drum. Do not connect a sheet to this side of the cord!
Good luck
For least amount of string use an arm winch, you may get away with a metal geared 12kgrm or more servo, plus an arm you will need to attach to a servo top.
Have you sorted the internals of a yacht before?
There is another option using a drum and that is to have a continous loop with the sheet (stringy bits - like it!) attached to it).
I've got to do the sails installation on one of my builds and did consider something else which is a linear servo that Hitec make. They are quite expensive but fancied giving one a go. Didn't in the end as they take up a lot of room lengthways and even the one with the most movement would require a pulley to increase the overall movement.
So I’ve bought a Kingmax Sail Winch Servo which are a popular choice and available in different numbers of turns.
Whatever method is used elastic can be used to keep the sheet under tension (as per the DF65 and 95 yachts) and reduce the chance of snagging.
Alternatively, below deck, as you mentioned for the linear screw, you can always run the sheet through a metal or plastic tube until it exits the deck.
Sail control
Having looked at the options for RC sail control there appear to be only two basic options, drum or lever (with variations) but all seem to have lots of string kicking around in the cabin. Has anyone ever considered or tried a linear lead-screw arrangement which can be shielded and can keep all the stringy bits under greater control. This would be driven by a separate motor controlled by the RC and the lead-screw can be by single lead, twin lead or even triple lead depending on sheeting speed required.
Any thoughts appreciated.
Le gusta a
Cargando…
