Dragonflite Sails
Iniciado por Heners2332
7 replies 21 me gustas Última actividad: hace 10 meses
#8 2
Dragonflite Sails
I’ve even used old fashioned drafting film in the past. I have a lot of it from my earlier working life in the 80s. Probably only good for smaller vessels? I’m guessing but it’s probably 10 to 25 thou thick. Yes I’m old 😊
Le gusta a AlessandroSPQR and hermank
#7 2
Dragonflite Sails
AndyB2
Yes, I did a similar purchase. Our local fabric shop had the end of a roll of RIPSTOP in the CHEAP BIN. On using sailcloth from a commercial sailmaker, the most applicable weight would be the sailcloth used for a full sized boat's light weight spinaker. Given what commercial sailmakers might class as scrap pieces, and the sizes of our sails. You might be able to get the sailcloth for scrap prices from the commercial sailmakers
#4 2
Dragonflite Sails
Ross gave excellent advice, a truly practical guide. It's clear he's faced these problems firsthand.
Le gusta a hermank and Ronald
#3 2
Dragonflite Sails
Hi!
Do you have a sail plan ready? or just copy the original
I have used RIPSTOP NYLON. Totally agree with using a soldering iron. Angled chisel tip for edges. Practise on little pieces before doing the full sail cut. Pencil point tip for grommet holes. Practise on little pieces to get your grommet hole size right. Do lots of grommet holes until you are happy with the grommet and hole match up
Tape you sailplan pattern to a heat resistant flat surface and tape your sailcloth on top of that. Use lines that can be seen through the cloth.
Also, luff line on the jib:
leave enough allowance for a seam on the luff
lay double sided tape on the edge of the of the cloth, I like 4mm tape
lay you luff line BESIDE the tape
fold over the seam and contain the luff line
zig zag stitch up the seam to secure it with the luff line inside
Reinforce corners before grommet holes.⛵
Questions?
Le gusta a Ronald and AlessandroSPQR and
#1 2
Dragonflite Sails
Hi, I have a DF95 and want to make some sails for it, how can I go about making sails?
