Mixer connections
Mixer connections
Mixer connections
The best way to do it is to use an extension servo lead and cut the red lead in the wire. Plug one end of the extension lead into the receiver and the other end into either esc.
That way the esc's remain intact.
Mixer connections
Unlike the one I have purchased for driving two small brushed motors directly from the mixer. To drive a small cat' model.
Mixer connections
The mixing is done before the esc is involved. It is possible the mixing has taken brushless operation into account.
Has anyone used one?
Mixer connections
This is a link to an image of your device showing connection details. Hope it helps.
I would have posted the image but it won't load here due to image type.
Mixer connections
These single wires fit into the normal 3 lead _ve, +ve signal servo connecter. But only the signal wire is needed.
I would suggest it is only a mixer and 2 off esc's are connected to the o/p of the unit and these drive the motors.
So you can operate the 2 motors from a 2ch. RC set. The rudder control balances between the motors.
If you want a rudder as well then you need a rudder servo and connect the signal wire to the rudder servo connecter in parallel.
Mixer connections
Mixer connections
Le gusta a
Cargando…
