Sailing barge sails
Iniciado por RickS
8 replies 15 me gustas Última actividad: hace 12 meses
#9 1
Sailing barge sails
Rick
It appears that in this photo there is a ruler of sorts? Using it along with the fill size ruler, measure the following:
Foot
Head
Luff
Leach
Send a photo of this when done.
Ron
Le gusta a RossM and hermank
#8 1
Sailing barge sails
OK it's not much but this is all that came with the hull. Regards
Le gusta a hermank
#7 1
Sailing barge sails
Ok, that's reasonable. Post a sail plan and we can get going
Le gusta a hermank
Sailing barge sails
She is 60cms by 17cms. Sorry I have not replied sooner but the Base Hospital is becoming my second home. Regards
Le gusta a hermank
Sailing barge sails
Rick
Just so we are all on the same page, a KITTY SIZED THAMES SAILING BARGE, is 65 tons and carries 1,000 feet of sail. How big a vessel are you working on. . . 😮?
Le gusta a hermank
Sailing barge sails
Hi Ricks, I also used cotton poplin, which is the most common fabric for elegant white shirts.
If you don't like white, no problem; you can dye it or give it an antique look.
Le gusta a hermank
Sailing barge sails
Hi Rick
Do you have a sail ⛵plan for your vessel? There are a number of us here that can work you through it, like Ron says
Ross
Le gusta a hermank and AlessandroSPQR
Sailing barge sails
Rick
Are you able to get cotton poplin or a bed sheet? Possibly some fabric dye to make sail a reddish brown ?
If so, then making your own sails is not too difficult, that is unless you’re wanting something that is truly scale with all those hoops and rope stitches that a real canvas sail would have on it along with grommets.
Just a thought
Le gusta a philcaretaker and JockScott and
Sailing barge sails
Hi all. I need a set of sails for a Kitty sized Thames Sailing barge sails. Regards
