Steam launch stability dilemma..
Seguidores (9)
- EdWBronze
- GaryLCSilver
- Newby7Bronze
- roycvBronze
- NickthesteamSilver
Always good to have a bit of displacement to play with, I am sure Nick would like some of that.
Stephen.
Then, thinking you couldn't, I suggested other solutions.
I'm glad you managed to do it (I didn't think there was so much wood to remove).
Anyway, looking at the boat from above, I realize its very atypical shape, referring to the width/length ratio. Longer would have been better (but that's the designer's fault, and you're working with what you have).
If you reduce the propeller shaft angle, don't worry; it's not a problem; in fact, it's actually an advantage.
I, if I can, position the propeller shafts parallel to the keel, so with zero angle.
and deck beams as possible without compromising the hull. (One deck beam is almost 1.5 inches thick!). This will allow the plant to be reinstalled at least half an inch lower, allowing the engine to be moved a little further aft. To achieve this it will be necessary to refit the shaft at a shallower angle. Well that's the theory anyway!
Yes, MSM have some very nice stuff.
Stephen.
In my humble opinion I would say that the steam plant is too large and heavy for the hull.
For my 2 cents worth, before you start doing major modifications try adding enough ballast to the stern to get her at least sitting on the water in a better attitude, I think it is worth a try.
Doing this in the domestic test tank (bath tub)would be preferable.
Good luck which ever way you go.
Stephen.
I am not a steam engine operator so if this comment is not possible please just trash it.
In my harbour I have three steam boats and I have had all of them running at one time or other.
I don't run them now as age has made it difficult to get them running.
I bring them to the pond as show boats
I love steam if it were me I would keep it as is and bring it with me to be show piece.
What ever you decide to do good luck.
Rick
No problem; it's likely that many problems have the same solutions.
In this case, there wasn't much choice, and magic doesn't work.
I have had a similar problem with a wooden boat that was unstable on the water. Final solution was to saw it into 2 parts and extend it by 25%, sails lovely now.
I expect the seller had the same problem, I would find a similar hull 50% longer and transfer everything into it. I like all the brass!
B.O.L.
I'll tell you what I would do: I'd remake the hull identically, but larger.
With a larger hull, the engine will be able to sit lower, and you'll have more displacement available.
Install a small electric motor in the old hull.
I think you, GaryLC, and Stevedownunder (and sorry if I forgot anyone) are elite ship modelers.
The problem isn't easy to solve.
I think there were design errors early on.
I see an engine too far forward. It should be moved aft.
I see a center of gravity that's too high.
How can I fix it? Can you move the steam engine unit?
Is it possible to lower it a bit and move it back?
Adding weights at the bottom and back to counterbalance has physical limitations.
While waiting for your answers, I'm thinking of something else, but it's not easy (after physics, there's magic, hahaha).
Le gusta a
Cargando…
