Fairey huntsman
Fairey huntsman
Sorry if I'm probing but I've got the Fairey T-shirt and anorak 😀 and am always interested in something that is different. Have you got a photo?
To answer your question. If it needs work then yes you could fit the strakes which will add to the looks more than anything. If not try it on the water to see how it performs before fitting them as you will need to remove the paint first.
Photos show the Spearfish out of the water and the Huntsman 31 Sport on it.
Fairey huntsman
The strakes or spray rails as the name suggests (stringers are actually part of the hull costruction and are inside), do deflect spray at the bow but also create lift to make it easier to get on the plane. This is more important on full-size boats though as they have limited power.
I thought the Spearfish had a fibreglass hull with integral strakes/spray rails? Or do you mean a Swordsman?
Fairey huntsman
Fairey huntsman
Had to smile at your mention of colour changing decking lights. I bought some, more years ago than I can remember, when I built the decking, and rather than building them in built timber enclosures for them, well I built 1 out of four! Trouble is the decking is starting to rot now so I need to do some repairs! They were expensive lights as well!
I may have to do some soldering soon as I'm gathering the parts and materials (brass) required to build the rudder for the Faun. I'll try the soldering iron first before the torch!
Edit: Managed to find a photo of the decking - wished it looked like that now and the one light!
Fairey huntsman
Fairey huntsman
Yes I do agree.
I went into a boat yard in Norfolk and he had a sign that read
" If boats where meant to be made of Fibreglass
Then God would have made tree from Fibreglass"
I do have one I built in wood way back in the 70's and have built a couple of others in wood and bought one wooden one that I gave one to my brother.
But I have also got a Fibreglass hull of one that I bought of just the hull and was going to build a top end on it of just a top of my own design.
Don't know what it will ever look like but I do have all the shapes of the wooden parts drawn around onto some heavy wall lining paper in case I ever wanted to build another one in wood. I done this from a previous purchased one.
Fairey huntsman
Fairey huntsman
Le gusta a
Cargando…
