Hitec HS 805 Winch
Iniciado por misterbee
12 replies 14 me gustas Última actividad: hace 2 años
Hitec HS 805 Winch
Not knowing anything about RMG products, I devised my own solution
1) winch motor and gearbox from ALIEXPRESS for about $25 CAD
2) wooden rings, available from most handicraft outlets for pennies each piece
3) couplers
4) framing that anybody around here can build
12 volt, completely separate power source
DPDT switches to the servos
HITEC 645MG servos
Lifts 2KG weight, 1.2 metres, in 10 seconds
different ratio gearboxes available
Le gusta a luckyduck and Cpt-Pugwash and
Hitec HS 805 Winch
I had a longtalk to the UK supplier, who said there should be no problems with voltage or current, but I will confirm before I buy.....
The RMG uses the direct battery for power, and I don't know if the Stinger is the same, I'm keen to find out, particularly as RMGs are getting rare due to manufacturing problems.
Regards,
Brian.
Le gusta a hermank and Cpt-Pugwash
Hitec HS 805 Winch
I have followed a recommendation to check out the "Red Ant" website, and contacted their UK supplier for details on the "Stinger" sail winch.
I'm very impressed, and will be getting one soon.
I'll let you know how it performs.
Le gusta a peterd and hermank
Hitec HS 805 Winch
Hi be careful of values of torque given as just 25 Kg. The unit should state the torque value in Nm ( Newton metres) or kgm or kgcm for example.Torque is a function of radius. The larger the drum diameter, or the longer a servo arm is the smaller the pulling force gets.They should state at what radius the 25Kg is measured at.
Le gusta a hermank
Hitec HS 805 Winch
I need a sturdy sail winch too. I’ve never used Ali Express before but noticed that they are selling a Kingmax SW22HV which is metal geared, waterproof, is programmable from 1.5 turns to 7 turns and around 25kg of torque. They give a ridiculous discount for first purchase so with tax and delivery I’ve got three for around £27. I’m not one for dealing with these Chinese sites but this seemed too good to miss. Delivery within 14 days.
Le gusta a hermank
Hitec HS 805 Winch
Thanks to everyone for the good info.
It looks as though what I will need is an RMG, or the cheaper Italian alternative, to get the amount of sheeting I need with the speed and torque.
Anyone have an RMG they want to sell? 🤣
Regards,
Brian.
Le gusta a hermank
Hitec HS 805 Winch
I agree just looked at the spec on Howes and Leeds model shop website it’s a servo not a drum winch.
Le gusta a hermank
Hitec HS 805 Winch
From HITEC:
805 is 60 degree rotation
Le gusta a hermank
Hitec HS 805 Winch
Agreed that the 805 is probably a sail arm winch, and I noted somewhere that they recommend powering the winch directly, as in the RMG,
I may have to see if it is, in fact, a sail arm, whether I can get enough travel by rethinking the sheeting.
This boat is 52" long, with lots of cotton sails to haul in.
A 75 year old Scottish pond yacht, she looks superb on the water, and keeps up with IOMs in a light wind,
Updates will be forthcoming,
Thanks for the input.
Hitec HS 805 Winch
Brian,
There is an HS785HB or HS788HB 3.5 turn.
153-183 oz-inch
11-13.2kg-cm
Is that enough torque?
The 805 doesn't mention multiple turns
Hitec HS 805 Winch
I need a hefty winch for my latest wooden sail boat, but I can't tell if the HS805 is a sail winch or not....i.e. does it come set up to do multiple turns as per the HS 765?
Can anyone shed light on this please?
Regards,
Brian.
