Mystery boat
Iniciado por AdrianS
4 replies 16 me gustas Última actividad: hace 2 años
Mystery boat
Anyone got a keel to fit this boat? Keel slot is approx 90mm long and 10mm at it's widest point.
Ewyasrover
Le gusta a hermank
Mystery boat
Found a bit more info concerning this boat. there is a label inside the hull stating; Tony Abel Yachts and Rigging.
I've found a few pics of the late Tony Abel's boat designs but they are all single mast, were as mine is twin masted with a winch system in the hull to control the sails by RC.
I'd like to know which model it is as the keel is missing and so I will have to make one, but have no size or weight info.
Boat is 1 metre long and mainmast is 1.2 metres.
Le gusta a hermank
Mystery boat
Hello Adrian,
It looks as if they wanted to recreate an AMEL Santorini . . .
Unfortunately I don't know if there is a kit or plans available
I happened to know someone with such a sailing yacht from the 1990s with a
length of 14m! And this on our medium-sized Lake Lucerne in central Switzerland!
Wish you “kind” winds.
Your Michel-C.
Le gusta a hermank and AlessandroSPQR and
Mystery boat
I was kindly given this boat as a winter project some time ago. Does anyone recognise it's make and model? It's missing it's keel, has fibreglass hull and is quite large, mainmast is approx 4ft tall. Any help or advice gratefully received!
Ewyasrover
Le gusta a peterd and hermank and
