Flywheels - gyros for stabilization
With reference to Roy (2 of 6) I seem to recall that Model Boats back in the 90's had an and article on the water in a tube idea.
Fred
The "bobbing and rolling" is not that noticeable to the observer unless one is specifically looking for it. However, it is quite noticeable in videos when recorded close up (or zoom in) or with an on board camera.
Florida ⛱️, USA 🇺🇸
Florida ⛱️, USA 🇺🇸
You said in your post "not spinning" not sure what you mean?
As far as bobbing about, weight distribution can help. Think of a barbell in weight training. If you ballast a model towards the bow and stern there is less bobbing about. But there is a penalty in steering.
I have a yacht that relies on internal ballast and not a deep keel and this does not bob about.
Cruise ships have stabilisers and there is an electronic device that senses movement that could be used to operate stabiliser fins. I think model helicopters and submarines use it.
A cheap way I read about was to have a tank of water like a slightly lengthened coke can and fill to one third with water. It would have baffles inside to slow the transfer of water from one side to the other and mounted high up.
This causes a delay in the water transfer and does combat the boat movement.
Intriguing!
I ask this because I accidentally came across a YouTube video of a model aircraft carrier (~ 4-5 feet long) that the owner installed a large stabilization wheel on the deck to counter roll. This wheel in effect shifted weight port and starboard, but not by continuous spinning. It worked.
This could have been simpler and below deck, but I'd did spark some interesting thoughts on reducing boats "bobbing" about.
I searched and found another YouTube video with a model boat hull about 30 inches long with a small gyro in it. I was amazed on how much it stabilized the boat.
Any thoughts?
Florida ⛱️, USA 🇺🇸
Le gusta a
Cargando…
