Fairey huntsman steering
I don't come here very often these days, picking this thread up a bit cold, attached is a pic of my prop, its called a cleaver. I tried many props, I like meddling, better than just sailing. I had an onboard data logger that measured amp draw and gps speed. Propguy helped me a lot and is worth a call if he still trades, I always said I would convert this boat to twin screw but never got round to it. When reaching max speed which was 25mph, the hull gets very unstable, as it want to roll over! Its a veron Huntsman 28, 4 foot long
As is often the case there is no right or wrong answer just choices. For sports cruisers a 3 blade prop is ideal as it gives plenty of shove and enough speed for planing boats. As I said 2 blade props are used but as alluded to they tend to be better suited to high speed and racing boats but sometimes they do use 3!
I've never heard or seen anyone using a 4 blade in a Fairey.
I have seen how his opinions and advice are always thoughtful and well-reasoned, but above all based on direct experiences.
Often practice in RC naval modeling is more useful than theory, because in scale models some effects are greater and others diminish, you don't get the responses you expect.
Without prejudice to your choice, just for a chat, I'll tell you that (all other parameters being equal: diameter, pitch, shape of the blades, materials) the more the number of blades increases, the more the speed decreases, but there is more stability (less vibrations), the more the number of blades decreases and the faster but more unstable the propeller.
If you are interested in the propeller, we talked about it in the following topics:
https://model-boats.com/forum/1353777
https://model-boats.com/wiki/137058
2 and 3 bladed are used (my 47" Huntsman came with a 2 bladed plastic one) but I much prefer 3 bladed brass/bronze ones as they just look so good!
Also, and whilst most of us don't build our Faireys to true scale in that we only have one prop shaft instead of two the full-sized boats have 3 bladed props so its a no-brainer for me! The only one of my Faireys with a 2 bladed prop is my Huntress fitted with a stern-drive and that prop is plastic.
As regards your mention of LiPo batteries earlier, yes, they can get very expensive! Especially the higher voltage and capacity ones. There's a few quids worth in a model if you add up the cost of the brushless motor, ESC and LiPo battery.
I may be wrong and I would think that someone will put me correct. Four bladded propellors I would think would be used on Navy ships like Destroyers. Aircraft Carriers and Tugs and Ocean Cruisers. I have a Aerokit's Huntsman and I have used a three bladded brass propellor but I had better performance with two bladded props but the sport type like 45s and 50s,
I all way's used to take a few prop's and take a few runs swapping props to see which one I got better performance with, by just going up and down in seizes.
I hope this explanation might just be a little bit of help or someone else might help you out.
Happy boating with your fab looking Huntsman.
Apparently up to the builder.
In conclusion. it is you the model builder who will make the decision. Forgive me for my ignorance.
I thought for cruiser type boats in the US and Canada the opposite is the case?
My 47" Huntsman which I bought built had the wheel on the right which I considered wrong for the UK.
Wez- good shout on the console. I have a Huntress 23 that was built by Dave Milbourn and I copied the console from that for my other builds and yours is very similar. No right or wrong anyway as many in the full-sized boats have been modified or replaced anyway.
Conclusion…. Your choice!
Le gusta a
Cargando…
