Glue
Glue
Glue
First time I've worked with a grp hull (and very sketchy instructions).
I'm starting a Mountfleet Models Brede which uses balsa to support the deck but will be filled around the deck to hull join with epoxy. I think I'll use the clear Gorilla glue for the supports.
I've read Brede build instructions on another forum. Any other hints gratefully welcomed
Glue
You need something that will seep deep into the wood. Possible let a full coat of super glue soak deep into the balsa (even the sides away from the joint) and let it dry, then apply another adhesive. Experiment first and let us know how it works.
Florida😎 , USA❤️
Glue
Yours is one of those questions that is liable to get many, some contradictory, answers. There are lots of choices, as Wez pointed out Gorilla Glue will work. So will epoxy, as well as polyester resin that has been thickened.. some of the answer is what you are comfortable working with. I would stay away from Super Glue, no matter the type or brand.
Le gusta a
Cargando…
