Servo question.
Seguidores (4)
Servo question.
But saying that it wouldn't matter if you already have a right hand as all that would be needed is to reverse the wires on your motor.
Servo question.
Servo question.
Servo question.
Your motor will give you a good speed with a 3 bladed prop of 25mm diameter. I would suggest trying a 7.2 v nimh battery to start.
Please post pictures of all your items as well as the model.
Servo question.
Servo question.
Welcome to the forum. I am sure you will find a wealth of information here. But it takes
some research filtering through all the threads to find exactly what you are looking for.
A 13 Kg servo is a very powerful one. That said, we need to know more information on
your intended boat size and intention of use.
There is a vast difference between a small tug plodding along and a large screaming high speed racing boat. Their set up is entirely different from each other.
With the 15 Amp ESC it would match a fairly modest size boat with a relatively small propeller to not overload the ESC. What is the motor capable of handling in the way of Voltage and Amperage?
These things need to be considered together to have a balanced system that matches
the boat of choice.
Please give us more information and I am sure the folks here can help.
Barry
Servo question.
In reply to your question, I take it your boat/ship already has its reciever connected to your esc, and motor.
The servo which I presume is for the steering will normally connect to channel 1.
With the esc to channel 2 for the throttle.
Other channels can be utilised for operating lights, winches etc.
Don't hesitate to ask for help, and it always helps if you can add pictures of your items and setup.
Servo question.
Le gusta a
Cargando…
