Steering competition
Iniciado por Jerry1
7 replies 9 me gustas Última actividad: hace 3 años
Hi Colin, thank you for the info. Many thanks Jeremy
Finally found the plans and scanned 'em.
If required I can get the rules etc
The pontoon is 4m wide, when competing the person can only move within the 4m space!
Sorry about the additions, my scanner was playing up! ----- Dooohhhhhh technology!!!
Le gusta a Scratchbuilder and Jerry1 and
Hi Bob
Thank you for the info. I will read it later.
Many thanks
Jeremy
Le gusta a Colin H
Jerry
We have a steering course in our program and I have attached the relevant sailing instructions. It has proven to be very successful for us. I could provide a copy of the score sheet if you wish.
Bob
Le gusta a Colin H and Jerry1
Hi I look forward to your reply tomorrow thank you.
Do you know about a "conning" competition? This is pretty wild.
This involves a two person team. Basically the "helmsman" (the one with the transmitter) faces away from the pond and the "pilot" passes verbal instructions the the helmsman.
The starting and ending points (can be the same) are usually some sort of dock requiring docking at the.
In-between are a number of obstacles to go around. This involves loops, turns, narrow passages, etc.
Missing the mark can involve deduction of points (if points are used) or having to turn around and redo the turn, etc. I like the later especially if on a clock timer from start to finish.
Have the course on a big board (like a map) is very handy. Set it by the water for the navigation team to view (see photo).
Lew,
Le gusta a Colin H and BarryS
Ok, I have been competing on one this afternoon here, near Roskoff, , basically a triangle with 30 m sides bouys etc, I have a plan I'm knacked now bur tomorrow I'll try and scan it, It is a french federation job!!
Le gusta a Jerry1
Hi All
Looking for ideas to put together for a steering course design.
I have a few ideas! So if you have a idea let me know please.
Jeremy 😎
