Mobile Marine Models T12 Alternative
Iniciado por AtreiusModels
3 replies 11 me gustas Última actividad: hace 3 años
Hi AtreiusModels
The T12 is I believe a 12v brushed high tork motor favoured by Tug modellers for its high pulling power. We really need to know what model you are going to install the motor in to and the size and pitch of the prop. There are many similar motors available and providing the details of the model will help making the best choice for your intended use.
Le gusta a Len1 and Scratchbuilder and
I suggest that you post the specs of the motor that you are looking to find an alternative for, for instance is it brushed or brushless? If brushed what is the case diameter and length? If brushless is it an inrunner or an OutRunner? And what is the KV?
VA3ROD
Hello fellow model mariners, I thought I'd posted this here before but could anyone advise on alternatives to the Mobile Marine Models T12 motor please? Thank you in advance 😊
I've contacted them and they're having issues getting them from the supplier and may be seeking to have them made elsewhere.
Le gusta a dave976 and hermank and
