Spektrum DX6i auxiallary chanel.
Iniciado por Nickthesteam
5 replies 6 me gustas Última actividad: hace 4 años
I am using a continuous servo to drive the pump, which is a piston pump, it has to overcome boiler pressure. I am waiting for an auto boiler control to arrive, but I was going to test the servo driven pump off the radio while I am waiting for delivery....
This is a relay switch that can turn on it off smoke, music, pumps, lights basically two relays that plug in a Servo port. Clean n cheap on eBay.
Howard hager
Le gusta a Nickthesteam
Is the pump a water pump? if so I use a esc for my water pump that way you can just plug it into any cannel. hope this helps.
Le gusta a Len1 and Nickthesteam and
the confusion and frustration you are experiencing is one of the main reason I switched to Flysky, I now use a FS-i6x and a FS-ST8. I am putting my new Spektrum TX16S up for sale.
LEN1
In settings each switch position has a setting right now you have switch on n off doing sane thing. Go to the switch and see on screen it says 100 or a number then switch the physical switch It will have same number but dial it a bunch so Servo arm moves. The physical switch when flipped will move as you set. In flaps it goes 100% + or 100% - spectrum manual is on line fyi if u don’t have it. Look up setting up flaps. Also the wing has to be set fir flaps and the switch you use assigned fir it. Manual will show you. It’s easy. I bought this item it plugs in as a Servo but has two relays the from centered will flip. Easier to use
Howard hager
Le gusta a TerryH
Hi, can anyone help me with setting up my DX6i? I am trying to make it switch a servo on and off to drive a pump, I am using a continuous servo and if I use the retracts switch it is permanently on, flipping the switch just reverses the motion. If I try the flaps channel, nothing happens... I am guessing the solution lies in all those menus, which I find most confusing...
Le gusta a FranklinL
