Motor cuts out
Seguidores (5)
Motor cuts out
I Like a man with a sense of humour 👍
Motor cuts out
Motor cuts out
But we all have different user names and I know it wasn't me so I don't get my knickers in a twist😮😁
Cheers, Doug😎 (aka RNinMunich or FLEET😉)
'a Doug by any other name ...'
Motor cuts out
Motor cuts out
Don't see your problem!?
Your registered user name is 'Ron' and RonB's is 'RonB'.😉
Not to mention that you are Vice Admiral and RonB is PO 1st Class so where's the confusion?
Motor cuts out
To help us to help you please post details; manufacturer, model/type number of the ESCs you have tried. Photos of all the ESCs, hi res so that we can see the maker and type number and any programming switches.
Most modern ESCs need to be taught by the TX which throttle stick position corresponds to; max forward, neutral and max reverse. Did you do this?
Also check if there is a switch to select type of battery; usually NiMh or LiPo.
This affects the pre-set per battery type Cut-off voltage setting of the ESC.
The wrong setting here could cause the ESC to cut off prematurely. The battery now OFF LOAD will recover slightly and the motor will run again - but only briefly as the load reapplied will cause the battery voltage to drop again. Eventually the motor will not run at all.
Another point-
If the ESC is designed primarily for RC Car use it will have a Brake function,active when going from forward to reverse, which you need to deactivate for use in a boat.
Check your ESC instructions for these points and let us know.
Motor cuts out
"Did you program the ESC?"
That was my first thought, but as you say without knowing precisely which components are being used it's impossible to diagnose the problem remotely.
Motor cuts out
What about the Tx and Rx, have you used them with any other models and if so did they work Ok? Did you bind the Rx with the Tx?
What voltage and type of battery have you tried? Was it/they fully charged? Did you program the ESC?
Lots of questions I know but we need to know the basics to help. Too many variables at the moment with trying different motors, ESCs and batteries. Need to try one thing at a time to identify the problem.
Motor cuts out
Motor cuts out
Le gusta a
Cargando…
