Another project boat
Seguidores (6)
- chugalone100Silver
- Newby7Bronze
Was a useful exercise in soldering brass, quite happy with the results, now using the new found skills to make A brackets for my BYMS.
I’m using a 180 degree servo for the sail servo with an extension lead to get the full 180 degrees of rotation, though have throttled the rotation back a bit via a FlySky Tx to stop the sail arm hitting the mast.
This simple arrangement works well as the main sheet length is limited by the shrouds.
Float tested the Jenny today, no leaks.
She does need some new sails, so I’ll have to give sail making a go.
As it happens I have a small fleet of Stars, think I’ve got 7 and a load of Bowmans and a miscellany of others (Ailsa, some unknowns and 3 1930s pond yachts for restoration). Think there’s about 20 pond yachts in house!
https://www.cornwallmodelboats.co.uk/acatalog/Jenny-Model-Boat-Plan-MM2070.html
Collected a lovely project boat today, anyone recognise the design? Hull is 25” long with a 5” bowsprit.
Has been built nicely and comes with a pair of elderly servos that I need to test. The sails are a little rusty and all the rigging and lacing lines need replacing after I’ve cleaned the sails and cleaned up the many brass fittings. The keel is weighted with lead shot and the lady I collected it from said it has been sailed by her husband, but a number of years ago.
Nice to collect a boat that doesn’t require too much work to get it back on the water, would be nice to identify it.
Le gusta a
Cargando…
