Submarine
Iniciado por StephenP
10 replies 4 me gustas Última actividad: hace 4 años
Submarine
I build subs and have had more than my share of questions. I have found Bob Martin at Nautilus Drydocks.Com to be a great source of knowledge. Contact him at sales@nautilusdrydocks.com.
Hope this helps.
Steve
Submarine
I build model subs and get a lot of support from Bob Martin at Nautilus Drydocks.Com. I am not sure what question you are trying to get answered but Bob's probably able to help
Submarine
Hi StevenP
As its a Resolution that means it is one of Ron's boats, his webpage is http://www.rcsubs.co.uk
Le gusta a StephenP
Submarine
Hi Tora
Sub is R&R model of hms resolution.
It has 2 metal piston ballast tanks and a dry compartment in the middle containing all the electrics.
It's all built in not a removable wtc.
Le gusta a Scratchbuilder
Submarine
Foe some reason my last post is not showing any comments, so here goes.
Hi StephenP
Have a look at this site , if you are unable to find an answer just post your question.
Just give them as mush detail as you can, may be some photos so that we can see just what is needed.
Submarine
Hi StephenP
https://www.theassociationofmodelsubmariners.com
Fred
Submarine
Stephen,
It sounds like you have what you need to make her go. It also sounds like this is a new used boat. Could you describe it more, ie, is it a dry hull, or maybe it has ballast tanks and a control compartment(like a ballast tank). What class boat is it? It could be an Engel, a Darnell, many possibilities and to narrow it down a bit would help immeasurably.
Submarine
Hello there everyone.
Just wondering if anyone has any information regarding static submarine diving gear wiring information. I have a sub that need a bit of Tlc . It has forward and stern blast tanks with motors...front and rear dive planes and rudder,seems to have attitude level switch and sub safe and batteries in series with speed controll for drive. Some of the stuff maybe duff...starting off on a new journey lol
