Propshaft to Motor alignment
Seguidores (7)
- RookysailorSilver
- mturpin013Bronze
- GregHiltzGold
- NickthesteamSilver
I make a solid joiner out of brass rod and drill and ream out to fit the motor and propshaft on my lathe.
Connect all up and adjust the shaft and fix the motor mount into alignment. When happy glue the shaft into position (I use plastic padding and roughen/degrease the shaft. Leave to set. Replace the solid joiner with a flexible coupling of your choice. If you have a lathe you can make your own.
This should ensure a correctly aligned motor and propshaft suitable for the fastest of craft. I also check my propshaft to make sure they are not damaged and run free and true. A flat pane of glass is useful to roll the propshaft to check. If it's not change it as it is unuseable.
perfectly, I suggest you purchase one of these
(link below).
They have various sizes to cover any motor/shaft variation, don't know what I would do without mine.
https://www.mobilemarinemodels.com/alignment-tool-71-c.asp
Cheers, Pete
I also bought it from Rich at Mack.
It is a little noisy at high RPM.
Trev
Have experimented with several types, the one on the extreme right shows the most promise.
The one next to it with the spiral cut works well, but is bulky and the shaft must be slide out to fit.
This one can be assembled is situ, is robust and allows a small amount of misalignment and vibration thus cuts noise down. Available through our friends at Aliexpress and Bangood
The others all have failings. The traditional Hookes joint style vibrate, wear and are noisy
The picture is of a heavy duty connector.
Peter
see my blog
https://model-boats.com/blogs/111186#112090
At times I have doubled up(back-to-back) individual U-Joint couplers to take up any variances.
Depending on which type motor mount, either hinged, or home-made, always allow for adjustment in the aligment.
But can someone advise the best way to align a propshaft to motor ?
Le gusta a
Cargando…
