Pulleys
Seguidores (5)
- mturpin013Bronze
- NickthesteamSilver
Pulleys
Thanks for you're insight as I had forgotten about how it would affect the being able to turn on the spot handling I have just now. I'd never manage that with both props turning the same way. I mainly run on one prop as it is just now. Both get used for my last run back to the pond docks though with my oversized rudders I get very good low speed handling with the one prop. Nice to have the other as back up
Scott
Scotland
Pulleys
However, with the boats I try working out solutions that will make the boat perform much better. This is why I use the multiple motor controls.
With a single control for multiple motors it is harder to maneuver around obstacles. Individual controls allow for some accurate maneuvering at a decent speed. This more accurately replicates movement of a real boat as I have yet to see a real boat using one motor to control two propellers. (I'm not saying they don't exist, just that I have never seen one.) Just my opinion.
Pulleys
My current project has two motors tow secs for differential control if needed though I have something for more complex setups. I don't like the norm of a simple setup 🙈. I love the look of gearbox's and pulleys when you get the setup just right. My RC helicopters are an example as after every flight I take all the head components and gears to bits and service.
Just find something very enjoyable about it all rather than bringing my boat home for a quick clean then sitting in shelf. I'm a tinkerer and addicted to it. Many years ago I had two Graupner gearboxes connected via a prop shaft and a motor at an odd angle just for the enjoyment of finding ways to try get it to run smoothly 😅
Scott
Scotland
Pulleys
The two motor/shaft/prop boats use two ESCs for independent control. (The current price for a Hobbywing 1060 ESC is about $24 (USD). As was said previously, you get much better control with this configuration.
For my three motor/shaft/prop boat I use two ESCs, driving the outer motors and the middle motor is turned on and off by a servo activated switch for a single speed forward (I don't see a use for the middle motor to go in reverse).
My four motor/shaft/prop boat (photo) is basically the same as the three motor configuration. Two ESCs, drive the outer motors and the middle motors are on a servo activated switch for a single speed forward.
I don't have any gears, belts, etc., only direct drives. The less you have between the motor and the shaft the less chance of anything slipping or breaking.
Pulleys
Pulleys
Pulleys
Pulleys
I currently have a twin prop setup and twin rudder. Mine both turn the same way though she doesn't have a turning effect and both rudders are at neutral trim. When using one motor just now she tracks almost straight as well.
Would the shape of my hull have a lot to do with this?
Scotland
Pulleys
https://model-boats.com/blogs/101943#103273
Pulleys
At first sight the idea of driving two shafts from a single motor has a number of attractions. Most noticeably you could gain from less weight and cost than using 2 motors and very possibly ESCs.
However, with gears or belts being used we could be left with more noise and opposite rotation from gears or broken bands from belts.
In both cases you also loose the one great advantage the of 2 motors and shafts ie differential thrust to aid forward and reserve manouvability.
As always and unless you are stuck with a second-hand model or a kit, the choice is always yours when designing and building your own boat!!
John. 😛😛😛
Pulleys
May be a bigger range than Proops?
Also>>>
https://www.gearsandsprockets.co.uk/model-making-pulleys-and-belts/
Pulleys
https://www.proopsbrothers.com/proops-gear-and-pulley-tech-set-model-cars-airplanes-boats-s7198-1354-p.asp
Or Expo..
https://www.expotools.com/acatalog/MOhttps://www.expotools.com/acatalog/MOTORS--GEARS---PULLEYS.htmlTORS--GEARS---PULLEYS.html
Le gusta a
Cargando…
