sprung forward deck
Iniciado por Stephen T
6 replies 1 me gusta Última actividad: hace 4 años
sprung forward deck
At last a sensible answer thanks for that ill give it a go
Stephen james tucker
sprung forward deck
no as it would be a complete strip out ive got the main deck to about 1.5 mm but the top layer of the deck is up a liile as well not sure what glue to use to hold its
sprung forward deck
Are you able to remove the deck? I think that is too big a gap.😛
sprung forward deck
I use gorilla wood glue on my boats, squeeze glue into gap and then apply binding around the joint. Leave for 24 hours, this glue is waterproof.
Le gusta a RedCatcher
sprung forward deck
Are you saying that there is a 3mm gap between the deck and frame work?
sprung forward deck
I have old keilcraft Raf tender at some point its had a bash at the front at the pointed bit and the deck has lifted partly from the frame work under what sort glue do i use to hold it down it moves about 3mm
