Wanted Plans
Iniciado por StanC
9 replies 0 me gustas Última actividad: hace 4 años
Wanted Plans
Stan,
I did see that FD had hull plans for the Texas, a New York Class BB. The follow-on class to the Wyomings. Dimensionaly they are quite close, only 11 ft differece in length and a few ft in width. Draft was the same. Building her in 144th scale would mean, if my math is correct(doubtful) that there would be about a 1/4" difference in lenght between a NY and a Wyoming. Just a thought.
Wanted Plans
Sorry Stan, But I have struck out as well for Wyoming's stations. It seems that even NARA does not have them. I'll check with the Smithsonian and I have one other possibility, but don't hold your breath.
Jonathan
Wanted Plans
Thanks Toradog,
I've found plans for the Alabama with the hull cross sections or what he is calling the stations. However, once again for the Wyoming class or USS Arkansas BB33 they do not have the "stations". I have found multiple overhead and side profile views just not the cross section to lay up a build.
Thanks for your assistance!
Stan
Stan C
Wanted Plans
The page I sent the link for states that not all files are available online, and suggests you contact them.
Regarding Alabama, I took hundreds of photos of her a few years back. If you need detail shots, let me know.
The worst day at the pond is better than the best day at work.
Wanted Plans
I found the architectural drawings there but they did not have the cross section for the Arkansas. I also found another site, https://maritime.org/doc/plans/index.php the San Francisco Maritime. Here I found the Alabama with the cross sections needed for forming her up. So for now I am still on the hunt for the Arkansas or Wyoming for the cross sections.
Stan C
Wanted Plans
Unfortunately not, for it is an Iowa Class battleship. However if I can't find one of the other two the Mighty MO is my third choice. I am looking for one that is not popularly modeled otherwise the Missouri would be my first choice.
Thanks for your reply.
Stan C
Wanted Plans
i have 2 sterling-Lindbergh USS Missouri kits. would those plans be what your looking for?
Wanted Plans
I am in search of plans in the scale of 1/144 of the Wyoming class battleship BB33 USS Arkansas and the battleship BB60 USS Alabama. Any help of finding a site that would have these plans would be greatly appreciated.
Stan C
